Thread: Caulk for the Coping/Patio Joint
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Gotta redo that joint. My bullnose brick coping abuts a concrete patio. Total distance around my irregularly shaped pool is about 140 feet. I'd like to make this a DIY job, since the pool guys in my area charge $10 per linear foot for recaulking.
    What product should I use? The joint is about 1 inch wide. Don't know how deep it will be after I put the backed rod in.
    Any suggestions?
    Thanks!
    Hank
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Guest
    Re: Caulk for the Coping/Patio Joint
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Thanks, Bruce!
    TF-100 test kit.
    Guest
    My pleasure!
    Feb 2008
    Denton, TX
    5,061
    Doubly thanks simicrintz. I've been needing to do this as well. Great instructions!
    Guest
    Happy to help! You guys can do this, and you'll save quite a bit of money. It isn't a real fun job, but you'll be proud of the end result
