Results 1 to 18 of 18
Thread: Skimmer Leak
    Oct 2010
    Central Florida
    10
    Skimmer Leak
    Hello everyone,
    I have researched for two weeks so as to not waste our time. I finally realized that the dye test was the way to go. I found some immediate leaks where the skimmer connects. The dye went straight to the spots illustrated. I am leaking about 0.75" a day, but the leak slows down drastically after water is no longer entering the skimmer. The leaks are outlined in the pic. You will see where a pool guy already tried laying down a cord of putty, but only the cheap fix only scratched the surface. My logic tells me that I can either keep patching or rebuild the area. I am asking for and I welcome your help! I will document my journey at this portal to help the site and those coming behind me!
    Thanks much.
    South Central NJ
    3,192
    Re: Skimmer Leak
    A 90 degree clockwise rotation would orient the issue a bit more clearly.
    Seems to me that the PB used a skimmer for a liner pool. Note the stainless screws. Skimmers for gunite don't have face plates.
    I fear the gunite near where it meets the plastic is deteriorated. How much it is not going to be known. I hope you're not in a freeze/thaw location.
    Are you showing 2 leaks, the second being in the plastic? If so, then combined with the leak where it meets the gunite, and that it's a liner pool skimmer suggest to me that the right way to fix this and never have it happen again is to replace the skimmer. I hope you have spare tile or are planning on retiling. I hope the deck doesn't suffer too much.
    Scott
    Owner of - PoolGuyNJ LLC
    Oct 2010
    Central Florida
    10
    Re: Skimmer Leak
    Not even close.
    Yes, at least two leaks and in those places to start.
    I have no replacement tile and did not plan on retiling..... but hey I hadn't planned on a lot of things. There a few more pics attached. I appreciate your input.
    Re: Skimmer Leak
    I would scrape off all the putty and cleanly apply PVC "dope" and once that dries, caulk.
    1971 San Juan Fiberglass pool 12,000 gallons
    New Pentair Whisperflow 1hp
    New Pentair FNS DE filter 64sq
    All 1.5" piping and no heater
    1 skimmer, 1 main drain, and 2 returns
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Skimmer Leak
    Welcome to TFP!!
    Scott made a GREAT catch on seeing that it's a liner skimmer installed in a crete pool
    There are ways to correct this, while keeping the skimmer you have - it's not optimal, but certainly less expensive than replacing the skimmer.
    The long and short of it is that you had a liner pool skimmer installed in a crete pool
    I, for one, appreciate your willingness to share your fix for anyone who might come here with a similar issue
    We (and that means everyone who is a member of TFP) will do our, collective best to help you with this skimmer problem - you chose the right place to place your trust
    Luv& Luk
    -Ted
    Oct 2010
    Central Florida
    10
    Re: Skimmer Leak
    Quote Originally Posted by vln
    Just my left brain - logical mind says that this bandage attempt is worth a try because of the simplicity of the solution. I am a little familiar with pipe dope and will go out and get some to play around with. I will not put any on yet, but I am entertaining your solution. If you come back to this thread then let me know if there are different grades of it or if pipe dope is just pipe dope. I appreciate your input.
    Oct 2010
    Central Florida
    10
    Re: Skimmer Leak
    Thanks Ted. I am usually not one to entertain bandage approaches, however, these alternatives to rebuilding the skimmer section might allow me to do the long term research I need to find out how to best and most cost effectively implement the long term solution of skimmer replacement. So if the bandage approaches can buy me a year or two, then I will use that year to my advantage and not sit back and procrastinate. You guys are right on target with your help. World Series time!
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Skimmer Leak
    I would try to prep the area the best you can and try plast-aid, it will bond very well with the pvc as well as the rough surface of the concrete
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Skimmer Leak
    just a thought, but perhaps a few coats of pvc cement to get the skimmer sealed up, then plastaid?
    Oct 2010
    Central Florida
    10
    Re: Skimmer Leak
    Xpert and Dman,
    I hear you. I have the these brands dope and cement in the pic. That Plastaid stuff looks like it might hold real promise. I have been watching the vids concerning it. Its on the way! I am thinking about:
    1) Chipping away that roll of putty that really didn't do the job.
    2) Prepping that plastic seam where the leak is using a very mild sandpaper
    3) Applying one or more of these temporary solutions
    This might buy me the time I need to keep the pool up and running while I research on the best way to expose (pull up) that concrete and find out a GOOD cement/pool man to place the right skimmer solidly down in there. We can rebuild it... we have the capability!
    I am having drink tonite (long overdue) and will pour out a little liquor for each of you guys.
    Mar 2007
    4,160
    Re: Skimmer Leak
    Spill a double for me, please
    I'd use an epoxy sealer (2 part), either putty or injectable over what I see in your pic. It's a 'band aid' but should give you the time you need to fully research your options for a more permanent fix Of course prep the area by removing any loose debris and clean the surfaces, as best you can.
    We are here with and for you whilst you decide on the best way for you and your pool!
    Luv& Luk
    -Ted
    Oct 2010
    Central Florida
    10
    Re: Skimmer Leak
    Ted, I got loose on the Grey Goose and watched the Heat whip up on the Magic!
    Here is the brand epoxy I was able to find (pic). Cures right in the water. I going to see if i can find a little literature on the particular brand but I am pretty confident working with epoxies.
    Oct 2010
    Central Florida
    10
    Re: Skimmer Leak
    Here is the data sheet and instructions for the Atlas Pool Putty (2-part epoxy). Attached
    Attached Files Attached Files
    Oct 2010
    Central Florida
    10
    Re: Skimmer Leak
    Alright I mixed it up and decided to give this stuff a try since this is clearly what was already put down. Its curing now.
    Mar 2007
    4,160
    Re: Skimmer Leak
    You used the same stuff I've used A LOT of times. As long as you packed it into the cracks well and feathered the edges, it should last a couple of years
    If you find yourself playing with this stuff again, I'll pass on a few tips on working with the 2 part epoxy putty (or maybe I'll just write up a little something when I have the time and proffer it up for the 'Further Reading' section of Pool School)
    I hope your patch will hold while you research your permanent solution options
    Luv& Luk
    -Ted
    Oct 2010
    Central Florida
    10
    Re: Skimmer Leak
    As long as you packed it into the cracks well and feathered the edges, it should last a couple of years.
    I spent a lot of time pushing the stuff all the way down in the crevices trying to make sure there were no air pockets. I feathered the edges though its hard to tell from the pics. The stuff feathers excellent with a wet finger tip. I am most paranoid that I didn't clean the surfaces enough. This stuff sticks really well to natural surfaces, but just slid any where there was the least bit of algae build up. I figured out that the algae did not like a cap full of bleach. Lifted the algae right out and made for a sticky surface. I will let this cure overnight to be on the safe side. I will be testing for the better part of the morning.
    Oct 2010
    Central Florida
    10
    Re: Skimmer Leak
    The pool putty spread in the last set of photos sealed the skimmer leak. The dye just goes straight down into the water and sits their indefinitely inside all parts of the skimmer. No dye going into the outlet hole either and that is also a real relief. I couldn't be more pleased with this patchwork.
    Now its on to researching the specifics of a completing a demo and rebuild of the area for the day that these patches no longer work. I will keep this thread updated.
    Mar 2007
    4,160
    Re: Skimmer Leak
    GOOD JOB!
    Slow and steady wins the race
    We'll help you figure out the optimal way of permanently correcting this
    Luv& Luk
    -Ted
