Thread: Blowing out main drain
    Hi all,
    When blowing out the main drain how do you know if an airlock has been achieved? I blow out the drain using a compressor, let it bubble for about 45 seconds, but after I close the valve I still get some bubbling here and there for a while. Is this normal or is the valve not closing properly perhaps? This is the first time I've closed the pool myself and I really don't want to screw it up
    Thanks
    Johnl's Avatar
    May 2008
    Montgomery County, PA
    88
    Re: Blowing out main drain
    I think your OK. If you had a leaking value, you would be losing pressure and the weight of the water would force the air back into the pipes, instead of out of the drain.
    I'm not an expert, so hopefully others will weigh in.
    23K Gunite IG Pool
    Waterway Crystal Water SVL56 Pump/1.5HP AO Smith Motor
    Hayward Star-Clear Plus Cartridge Filter C17502
    Aquarite 40k SWG
    Polaris 360
    South Central NJ
    3,192
    Most drain lines run horizontally before going up. This section usually refloods untill the rise in the line is above the drain. An air lock will prevent any further water from entering the rising pipe. That elevation is typically well below the frost line by several feet.
    Scott
    Owner of - PoolGuyNJ LLC
    Thanks for the quick responses.
    Gonna call it good and put the cover on.
    Thanks again
