Results 1 to 8 of 8
Thread: where to put valves for hard piping?
    Mar 2010
    Huntington, WV
    150
    I hope to hard pipe my AGP pump/filter setup for the upcoming season next year. I also hope to add a SWG to it. I was wanting to know the proper places to plumb in the valves?
    24' AGP
    Hayward Power-Flo LX 1.5hp pump
    Hayward Pro Series S180T 150lb sand filter
    Intex 54601EG Krystal Clear SWG
    Diver Dave pool cleaner
    22,551
    Re: where to put valves for hard piping?
    My valves are right near the pump suction and the filter discharge but I wish they were near the skimmer and the return. It probably doesn't matter which end they're as long as you have them on each line. I'd recommend using full port valves too. Not the restricted valves you buy at Lowes or HD.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Mine are right after the skimmmer and before the return. I also have a whole other bunch of valves, but are there to support the on/off cycling of my solar panels.
    Mar 2010
    Huntington, WV
    150
    What are the full port valves compared to the ones at BORG?
    24' AGP
    22,551
    Full port valves will say that on the description. Jandy, Pentair, Hayward style valves are all full port valves. It basically means that the hole through the valve is the same size (or larger) than the connecting piping when open.
    Mar 2010
    Huntington, WV
    150
    I see. What about unions? Should I use them and where?
    24' AGP
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by Jeff74
    You'll get differing opinons, but I used plenty of them (at every connection...eg. after skimmer valve, pump inlet, pump outlet, filter inlet, filter outlet, before the return valve.), makes winterizing and servicing the pump/filter a snap but some will argue it increases the risk of leaks, which is tru but is minimized by keeping the connections snug and o-rings lubed.
    22,551
    I vote for unions too. Use enough of them to be able to remove any piece of equipment without having to un-plumb it. I'd say 3 minimum. One before the pump, one between the pump and filter and one after the filter. One in the waste line if it's hard piped too. Ones near the skimmer and return are optional.
