Results 1 to 7 of 7
Thread: Georgia: Bison rescued from swimming pool
    sonflower's Avatar
    Jun 2010
    Fort Worth, TX
    157
    Pool: (2003) IG Plaster 14,209 gallon (Water Surface 421 sq. ft.) ~ Spa: 18" raised kidney
    Triple spillway (Waterfall) ~ With 6' slide ~ Hayward's Goldline Controls Aqua Rite Digital Electronic Chlorine Generator (Salt System) ~ 40K Salt Cell ~
    ~ AquaLink RS -4 ~ Purex Whisper Flow 2 HP~ Aquatech 60 sq. ft. DE Filter Normal Pressure 22 # ~ MiniMax NT (Propane) Heater 400,000 BTU ~ Jandy Valve Actuator ~Letro Legend Cleaner ~ K-2006 & K-1766 Test Kits
    Dec 2009
    Central Massachusetts
    2,690
    Re: Georgia: Bison rescued from swimming pool
    That look like a Loop-loc or a similar type safety cover. I thought they were supposed to hold an elephant
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    Someone needs to e-mail this gent the inground closing instructions too...looks like that cover has been on for quite some time
    Mar 2007
    Coastalish 'down easter'
    4,160
    Quote Originally Posted by bk406
    Elephants don't have hooves (a deer will also tear through a safety cover, and wreck the liner ... been there done that )
    Luv& Luk
    -Ted
    Dec 2009
    2,690
    Thats what homeowners insurance is for
    Depending on how long that creature was in the pool, it might be time to replace the filters! If it were me, I'd probably have to drain and refill. Just the thought of swimming in the same water as a big wet fur-covered hamburger...
    Casey's Avatar
    SW PA
    10,290
    I'm glad the guy found him before he drowned! I'm having a hard time NOT thinking about the "if" he didn't see him in there... because no leaf rake would get what laid at the bottom of that pool come Spring!
    There'd definately be a Thread... "Why does my pool stink like a dead bison after adding 958,210 gallons of bleach? <with pics>
