Thread: Can I use a solar cover for winter months?
    I live in Houston so no problem with freezing. My problem is I have lots of leaves that fall in the pool staring now. I want to get a solar cover so I can have a longer swim season. So what if I use a heavy solar cover and let it overlap the sides of the pool like a winter cover and not trim it to the inside of the pool. This way I could blow off the many leaves that fall on the cover. Do you think that this will work? The guy at the pool store seems to think so. What do you think?
    Steve
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Can I use a solar cover for winter months?
    Welcome to TFP!
    It sounds like it should work so long as you tie down or otherwise hold down the cover to prevent it blowing away in wind. I have an automatic electric safety cover and it works just fine in the winter (no freezing of the bulk pool water where I live) and keeps the pool free of debris. You might get a pool cover pump to prevent water from pooling on top of the cover.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    My opinion is if the cover is larger than the pool, the wind will roll it over and dump all the leaves in the pool and possibly put the cover in the yard somewhere.
    Rain water will collect on top of the cover, and you can't blow wet leaves or leaves that have been wet on the cover.
    During the summer, my pool gets much more debris in it when the solar cover is on, because the dirt lands on the cover, but the skimmer doesn't work with the cover in place.
    Oct 2010
    Georgia
    317
    Steve
    Use a solar cover during the Spring and Fall to extend your swimming season, but buy a good quality winter cover if you close your pool during the Winter.
    A good solar cover can extend your swimming season by several weeks each Spring and Fall. We have all seen advertisements for 15 degree increase in water temp with the use of a cover, but we usually see a 5-7 degree increase in water temperature with the cover on our pool. The solar cover with a heater or heatpump can extend your season by 4 months. We open our pool two months earlier than our neighbors and we swim long after they have stopped using their pools.
    We tried using the solar cover as a Winter cover only once and the results were a disaster for our pool and for our cover. We will not make that mistake again. The leaves and debris stuck to the top of the rain soaked cover and formed a slimy swamp during the winter. In the Spring, we spent hours trying to remove the now very heavy cover without spilling the leaf muck into the pool and without tearing the cover. We ended up with loads of green and brown slime from the decomposed leaves, algae and debris in our pool. It took hours to clean out the solid debris, several gallons of bleach for several days and almost a week of constant run time and several backwashes for our DE filter to return the water to it's former sparkle.
    The layer of moisture on the cover throughout the winter would freeze and thaw even in our mild SE US Winters. We believe this shortened the life of our solar cover. It may have simply been the extended time in the Sun or the decomposing leaves that caused the cover to break down. If you use the solar cover as a winter cover then it will see a much shorter service life. We now store our solar cover during the Winter and it lasts much longer.
    We don't use a Winter cover because we don't close our pool.
    Here is how we manage our pool throughout the seasons in a climate that is very similar to Houston. We generally stop using our pool in late October or early November, but we don't close it. During the Fall, it takes about 10 minutes each day to clear the skimmers of leaves and to scoop out the floating leaves with a large leaf net. The Polaris 280 clears the leaves that sink to the bottom so the debris bag on the Polaris needs to be emptied daily. This LEAF MADDNESS only lasts through November and from December until March we do very little to the pool.
    We keep our water balanced throughout the Winter months, just like the rest of the year. When water temps are below 50; the SWCG does not operate, so we add a little bleach or toss in our "Puck Duck" to maintain our normal free chlorine level. CYA levels increase only a few ppm with the use of the pucks for a couple of months during the Winter and normally decrease slowly due to backwashing and rainwater dilution throughout the season.
    We believe it is easier and more cost effective to keep the pool open in our climate and to do a small amount of pool upkeep during the non-swimming season rather than have the added work and costs of closing and opening. It is not necessary to test the water as frequently during the off season, but it is still a good investment to spend a little time and a few dollars on testing regents and water balance chemicals to prevent any potential problems.
    When Spring arrives, usually around April, our water is already balanced. There are no algae blooms or water issues to deal with. No opening kit or special chemicals are required. There will be no need for powdered shocks, algaecides, clarifiers, floculents, cleaners or enzymes. We simply add the solar cover, turn on the heatpump, and within a few days... swim.
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
