Thread: How much antifreeze to add?
    I bought 6 gallons of antifreeze to add to my lines for closing. Pad is about 25 feet from the pool. Will this be enough?
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: How much antifreeze to add?
    there should be a chart on the bottle that tells you how much to use based on length of pipe and diameter of pipe.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    It's RV antifreeze. No chart.
    10,000 gallon
    NC KANSAS44
    X-PertPool's Avatar
    Exeter, PA
    1,385
    you can try checking out a pool store and comparing the active ingredient( if they list one) in the bottle, if they match with roughly the same percentage you might be able to use that chart.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
