Results 1 to 8 of 8
Thread: Closing instructions for curing plaster
    Butterfly's Avatar
    South Carolina
    10,045
    Maybe I should say, "When the water temp drops below 60 degrees, do we need to do anything other than the ordinary closing procedures if we have plaster still curing?"
    Joyce
    You're done SLAMing when:
    KurtV's Avatar
    Mar 2007
    SE Louisiana
    270
    Since your new plaster went in in March, I think it's safe to treat it like
    old plaster.
    Butterfly's Avatar
    South Carolina
    10,045
    Thanks, Kurt, but when is it going to start ACTING like OLD plaster? I still add MA every 3 or 4 days....7 or 8 cups per week! What happens to the chemistry when the water temp is below 60 degrees?
    Joyce
    As the water cools all of the chemical reactions slow down. You should start seeing this even before it gets down to 60 degrees.
    KurtV's Avatar
    Mar 2007
    SE Louisiana
    270
    Quote Originally Posted by jjparrish
    Thanks, Kurt, but when is it going to start ACTING like OLD plaster? I still add MA every 3 or 4 days....7 or 8 cups per week! ...
    Joyce
    I don't know. Mine is almost two years old and my pH is still constantly rising. Even with a total alkalinity of 60-80 ppm (depending on the pH, 50-80 ppm borates, and using tri-chlor most of this summer. Some pools are just acid eaters.
    Butterfly's Avatar
    South Carolina
    10,045
    Kurt, would you tell me what your water chemistry did last close/winter and what you did about them?
    TIA, Joyce
    KurtV's Avatar
    Mar 2007
    SE Louisiana
    270
    I don't close as the climate here is mild. I probably added acid once a week or so from November through March/April. I try not to fight the pH too much. I let it drift up to 8 or even a little higher and then only take it back down to 7.8 or so. I use a lot less acid this way than when I was trying to keep the pH down in the 7.2-7.6 range.
    Butterfly's Avatar
    South Carolina
    10,045
    Kurt. We don''t 'close', either. Will keep an eye on the pH throughout the season(s)
    Thanks for your comments.
    Joyce
