Thread: O-Ring Product?
    Lehigh Valley, Pennsylvania
    71
    O-Ring Product?
    What is the best product to use on seals (filter o rings, etc.) when closing a pool?
    Thanks
    25K gal vinyl inground, 1HP Hayward Pump, Hayward DE 4820 Filter
    22,553
    Re: O-Ring Product?
    Silicon pool lube is the best to use. It doesn't attack the rubber compounds and it's easy to clean up if needed.
    4JawChuck's Avatar
    Jun 2010
    Winnipeg, Manitoba, Canada
    223
    Re: O-Ring Product?
    I use Dow Corning High Vacuum Grease, it is commonly available over the counter at many automotive suppliers. Its a little thicker than some silicone greases so it works well for difficult to seal threads and also has multiple uses around the garage like for spark plug boots etc. Its 100% silicone product and safe for all plastics
    http://www.ellsworth.com/display/pro...03&Tab=Vendors
    http://www.dowcorning.com/applicatio...8817&type=PROD
    One tube would last you a lifetime.
    55 Kilolitre in-ground 18'X36' vinyl lined kidney shape, 1HP pump, Jacuzzi 250lb sand filter, RayPak Delta T 200K BTU natural gas heater. New PoolWerks "Blue Diffusion" liner on May 26th-2011
    Avatar is my pool!
