Thread: Down East Hot tub
    Down East Hot tub
    Hi
    Have a Down East hottub, either 2001 or 2002. Was playing with the panel the other evening and it popped up with F1 thru F12. I didn't know what this was and now the tub is running constantly and I cannot figure out how to get back to the F's which I now know is for pump duration. This was a used hot tub and did not come with the owners manual and the company says they do not have one?!? So, does anyone have an owners manual that you can help me with the programming. It has 4 buttons, up and down arrow, jet and light button and a temp readout.
    Thank you
    Kay
    26,000 Gallons in ground with spa
    SWG
    Jandy equipment
    Re: Down East Hot tub
    So no one has a manual. Ok, how about my new problems. Light button and the light are blinking on and off, cannot turn on the high speed on the pump and the temp up button works but not the down button. The pump continues to run on low speed and it does heat. Does this sound like the control panel? Just hate to spend $130 and it not fix the problem. And one thing I forgot to mention is that we filled the tub to full and when several people got in, it overflowed. The control panel is in good shape and I'm just wondering if water got in it. Could this have started these problems because it was working fine before.
    Thanks
    Kay
    SWG
    Jandy equipment
    22,553
    This is the slow season around here and it may a little while before one of the spa guys sees this. Be patient and someone will come along if there's anyone out there knows about your particular spa.
