Thread: Muriatic acid question
    phalcon51's Avatar
    Oct 2010
    So. California
    203
    I'm using the Pool Calc app on my iPod and in the setup section it asks me to specify the acid strength. It defaults to 31.34%. Is this typical for pool store acid in CA? The bottles I bought from Leslie's don't give any strength information on the box or the label. The other choices are 15.7%, 28.3% and 34.6%. Can anyone confirm what strength acid I'm using or how I can determine it?
    Thanks
    26,200 gal. 35' x 16' Plaster IGP (50 yrs. old), Hayward 48 sq. ft. DE filter, Hayward EcoStar VS pump, Intellichlor IC-40 SWCG, The Pool Cleaner 4X suction, Pool Skim and Pool Devil skimmers. Re-plastered Sept. 2010.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Muriatic acid question
    That's pretty standard concentration as far as I can tell. I used to buy it at Leslies, but I found a cheaper source with returnable jugs. It has to say somewhere on the box or the bottle. But anyway, here's how you can tell: add what poolcalulator tells you, run the pump for an hour or so and recheck pH. If it went down the right amount, you have the right concentration. Assuming you have the volume correct....
    Mar 2007
    San Rafael, CA USA
    12,082
    Leslie's Muriatic Acid, as shown here, has the concentration of Hydrochloric Acid on the box. This link gives you access to the MSDS which gives a concentration of 25-36 and is most likely to be 31.45% as that is standard.
    phalcon51's Avatar
    Oct 2010
    So. California
    203
    Thanks for the quick replies. This forum is great!
    Quote Originally Posted by Richard320
    Can you name your cheaper source? I live in Monrovia, not far from San Dimas.
    Mar 2010
    Spring, TX
    1,082
    I get mine at wharehouse pool supply, 4 gallons for 19.99. Home depot sells 2 gallons for 11.99.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by phalcon51
    Johnny's Pool Supply In Covina. On Barranca Ave.
