Thread: Closing pool that was never opened??
    I have an above ground pool that was never opened this season. Is there anything I should do for this upcoming winter??
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Closing pool that was never opened??
    Welcome to TFP...just my opinion, but if the cover is still in good shape and the water level is OK, the situation under that cover won't get any worse over the winter.
    It likely turned to pea soup over the summer if there has been no circulation or FC added, but once water temps drop below 60 deg, it shouldn't get worse.
    Well, never opened it due to moving etc, etc. So what am I going to do next spring? I'm worried about what I'm going to face next spring!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Well, you would be facing the same task now, just to cover it up again. My point is most of the damage is done, but if you prefer to clean it up now, I would suggest reading through pool school, specifically
    pool-school/defeating_algae
    and
    turning-your-green-swamp-back-into-a-sparking-oasis-t4147.html
