Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 88
Thread: Your Pool - from SPACE
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    We built a house two years ago. For the longest time, just an empty lot appeared on Google Earth.
    Finally, it looks like the satellite made a pass over my property. From what I can tell, it looks like this was taken 6-8 weeks ago.
    Lets see yours!
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Your Pool - from SPACE
    Nice looking place! That's a fairly low level aircraft photo, not a satellite image. Many states that have a lot of agriculture pay for the aircraft photography.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Ha, cool idea! Here's mine. Google Earth (the stand-alone program) has a feature where you can see the same site on various dates...pretty cool. This one is from Nov. 20, 2009.
    And, from May 30, 2005:
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Hmmm, interesting, would these low level aircraft images make it on to Google Earth?
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by JohnT
    Google earth is satellite images, not aircraft. If they were aircraft, you couldn't zoom out like you can. Yes, satellite imagery is that good.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    A pic from google earth from my previous house:
    Really amazing what satellites can do.
    1971 San Juan Fiberglass pool 12,000 gallons
    New Pentair Whisperflow 1hp
    New Pentair FNS DE filter 64sq
    All 1.5" piping and no heater
    1 skimmer, 1 main drain, and 2 returns
    SW Indiana
    9,198
    Quote Originally Posted by bk406
    No, Google earth uses aircraft images when they are available. That kind of resolution comes from aircraft at only a few thousand feet.
    From the Wikipedia article:
    "Most land areas are covered in satellite imagery with a resolution of about 15 m per pixel. This base imagery is 30m multispectral Landsat which is pansharpened with the 15m [panchromatic] Landsat imagery. However, Google is actively replacing this base imagery with 2.5m SPOTImage imagery and several higher resolution datasets mentioned below. Some population centers are also covered by aircraft imagery (orthophotography) with several pixels per meter. "
    Note that 2.5 meter resolution means you can see a car. If you can identify the model, it is an aircraft photo.
    Dec 2009
    2,690
    Where'd you find that info?
    Oct 2009
    3,899
    Especially the oblique shots like what vln posted (available on Bing and elsewhere). That kind of imagery may be possible from satellites (depends on how much Tom Clancy you read ), but I kinda doubt it. Too much interference from the atmosphere.
    Dec 2009
    2,690
    Ok, so most are satellite, some are aircraft. Yes, the oblique pict is for sure aircraft.
    Learn something new everyday.
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Looking at my image more closely, is see PAMAP/USGS written on the bottom.
    Googling PAMAP/USGS, I find http://www.dcnr.state.pa.us/topogeo/pamap/index.aspx
    This site states that PA is indeed using low level aircraft to map the entire state.
    Ya learn something new everyday!
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    The last time the Google Earthbots were over our house was in 2004. I guess I see where we stand in the big scheme of things....no pool to show. Their loss!
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    SCEADU's Avatar
    Feb 2010
    Atlanta,GA
    68
    Try Bing Maps... I us it for my online clients in other states. It has a bird's eye feature that allows you to see the house form N,S,E, and W as long as they have the photos. I was even able to tell a client where their septic system was from the air. The one picture was when they were building the house and caution tape could be seen where they had put the tank in.
    Western Pennsylvania
    151
    Bing maps look really old, the view of my house is at least 4 years old, Google is up to date.
    But the Bing maps pan feature is nice
    15ft round above ground pool (6600 gallons)
    Sand filter
    Jandy gas heater
    Intermatic timer
    SCEADU's Avatar
    Feb 2010
    Atlanta,GA
    68
    Some of their photos are really good and others aren't so good. the good ones ar usually aroung growing communities it seems.
    Oct 2009
    3,899
    Google Earth seems to have a function where they update areas with very old imagery if lots of people start looking at it all of a sudden.
    We did a job in SE Alaska last summer in the middle of nowhere. In the planning stages, we did a lot of Google Earth-ing around the area, but the imagery wasn't good. After a few dozen people were looking at this one spot all the time, they updated the imagery, which meant we had to re-do a bunch of work! Much better results though. It could have just been a coincedence, but Google is pretty smart about such things so I suspect they were paying attention.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    terraserver looked to be the most up to date but it's not free unless you want the image full of watermarks
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Aug 2010
    Sarasota, FL
    22
    [attachment=0:ndf77ak0]GoogleEarth_Image.jpg[/attachment:ndf77ak0]
    20k gal pool/spa, marc, 2 hp pentair whisperflo, Pentair clean & clear filter, Raypack Reheem 266 heater. Taylor K2005 test kit.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I work for a large Geogrpahic Information Systems (GIS) company, we were using "Google Earth" before there even was a Google.
    You'd be amazed at the amount of data that most municipalities have these days and the sophisticated ways in visualizing it.
    In our situation we have virtually every municipal and utility feature (water/sewer mains, poles, hydrants, your lot and house footprint, assessment info, meters, cables, pumps, road edges, etc etc) geographically located and sitting overtop satellite imagery.
    It pretty amazing and the commercial grade software is far more powerful than Google Earth, Googles major feat is delivering something so solid to the masses that is easy to use.
  20. Back To Top    #20
    Nov 2010
    Escondido, CA (San Diego area)
    24
    Sadly, me too, and no that isn't a green painted pool -- shh, my wife hasn't seen it yet!
    Roland
    28,000 gals, In Ground / Plaster, spa, cartridge filter (STA-RITE System:3, 300 sq.ft., 100 GPM max flow rate), 2 HP pump motor
