Good Morning All,
I am going to winterize for the first time this year. I did a sort of dry (wet) run and was able to blow out the returns and fountain with no problems. I hooked up my air compressor to the pump and blew them out that way. I attempted to do the skimmer and main drain and here is where I got a bit confused. I have a check valve that would prevent back flow to that area. I attached a pic showing my setup. In the pic is the main drain return and skimmer. How do I blow these lines out with the check valve in place? My thought is to blow out from the skimmer or from the basket area at the pump with a homemade blow out plug. Thanks in advance.
