Results 1 to 7 of 7
Thread: Blowing out Main Drain and Skimmer
    Good Morning All,
    I am going to winterize for the first time this year. I did a sort of dry (wet) run and was able to blow out the returns and fountain with no problems. I hooked up my air compressor to the pump and blew them out that way. I attempted to do the skimmer and main drain and here is where I got a bit confused. I have a check valve that would prevent back flow to that area. I attached a pic showing my setup. In the pic is the main drain return and skimmer. How do I blow these lines out with the check valve in place? My thought is to blow out from the skimmer or from the basket area at the pump with a homemade blow out plug. Thanks in advance.
    22,548
    Re: Blowing out Main Drain and Skimmer
    You could remove the flapper in the check valve and your scheme would work.
    Johnl's Avatar
    May 2008
    Montgomery County, PA
    88
    I blow my main drain out through the pump.
    23K Gunite IG Pool
    Waterway Crystal Water SVL56 Pump/1.5HP AO Smith Motor
    Hayward Star-Clear Plus Cartridge Filter C17502
    Aquarite 40k SWG
    Polaris 360
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Agree w/ Bama; just unscrew the clear cover, remove the guts, then replace the cover.
    Thanks to all for the advice. I had thought about just reversing the valve prior, but removing the guts is probably a better idea. I will let ya'll know how it turned out.
    Rod
    Thanks again. Removing the flapper from the check valve worked perfectly. I was amazed how quickly my main drain started bubbling using my compressor.
    Oct 2009
    3,899
    Glad it went well!
