Thread: Cover extremely heavy. What to do?
    I bought the house I live in about a year ago. It came with a Caldera Watkins Elation that looked to be in decent shape. I don't know how old the cover was at the time. Over time, the cover has gotten heavier and heavier. Now it's so heavy I can't even lift the cover off the tub.
    It feels like there's water accumulating on the underside of it. The bottom is sagging so much because of all the water that it's actually touching the top of my spa water.
    How do I get it out of there?
    Austin, TX
    500 gallon caldera spa
    Monarch silver ion cartridge
    Re: Cover extremely heavy. What to do?
    Are you thinking it is a total loss? If so I'd probaby drill holes through it and let the water drain into the tub. Likely after it is all over it will be time to change the water.
    DISCLAIMER: I've never been in this situation so just letting you know what I would likely do/try!
    -Chak
    290 Gallon fiberglass reinforced acrylic spa
    Cartridge filter
    Above Ground
    2 x 5HP pumps - unknown flow rate.
    Ozonator
    6800 Gallon 17' x 48" Vinyl above ground pool (Summer Escapes)
    Intex 2650 Sand Filter
    You've never had this happen? There seems to be consensus after searching Google that these.covers tend to wind up water logged :/
    Austin, TX
    Jan 2009
    Cupertino, CA
    1,966
    Early on, I was advised that every 2-3 months (e.g. every water change, if that's how often you do it) to unzip the covers and let the foam air out overnight. Not that I actually do that, because I haven't had the cover-too-heavy problem.
    --paulr
    BBB "Intermediate Swimmer"
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by ding0k
    You don't. Buy a new cover. Look on-line and buy the cheapest one you can find.
    That's what I did. Cover got so heavy I couldn't get it back on the spa. The new one must be better quality - over 5 years old and still as light as the day I bought it.
    Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    Quote Originally Posted by CUTiger78
    Good luck!
    Do you remember where you got yours from?
    Austin, TX
