Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Amerilite Pool Light Leaks. A Fix and what I've learned
    Bobbystone
    Guest
    One of the first things i noticed on my first pool at teh house I just moved into was that the shallow end pool light was not functioning I did a bit of research and ordered the new gasket and lamp. Installed it and everything went well for about 3 minutes when "Blooouup" a big ol bubble arose. That left me into further research and investigation. I dried everything out for a day, and put it all together again, being more careful this time to make sure everything was in alignment. Once again, the bubbles arose. Yesterday I went through the procedure again, but this time I held the lamp underwater while it heated to see where the leak was actually coming from.
    Eventually I saw a steady stream of bubbles emanate from the strain relief where the cord goes into the fixture. Here's the fix I devised.
    I had some west system G-flex epoxy which is a 2 part epoxy that retains some flexibility and will bond do almost anything. I mixed up a batch and coated the juncture of the strain relief and cord, trying to get as much in the crevice as I could. Let it cure, and re-tested this morning. It worked like a charm! I was in too much of a hurry, but here would be my suggestion for doing a better job of the fix:
    First I'd make some sort of ",old" around the cord to hold the epoxy in while it cures. You could to this with tape possibly or with some sort of plastic tube that you could hot clue to the fixture. Or you could even hot glue some cardboard to make a box around the cord, This would allow you to make a bigger chunk of epoxy around the leaking area. Mine is definitely not pretty, but it did seem to work, so I left it alone.
    Other notes:
    Before I tightened the retaining wire around the gasket assembly, I turned the lamp on and let it heat up the air inside a bit. I've read a lot about NOT doing this, but my thinking is that a big part of the problem is the expanding air inside the fixture which seems to leak out, breaking the seal and then invite water back in when the lamp cools.
    When I put the lamp housing / gasket assembly back together, I did it with the lens facing up. This let the hooks hang down and was easier to get the wire around all the rings, and made it easier to get everything aligned. If you put it together lens down, the trim ring is hanging down below the curved lens and its harder to get back together.
    Hope this helps someone in the future. Now I'm wondering if G-flex epoxy might be the answer for my leaking skimmer boxes
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Amerilite Pool Light Leaks. A Fix and what I've learned
    Thanks for the tips! You never know when a post like this will be exactly what some poor soul is looking for...
    Bobbystone
    Guest
    Amerilite leak fix Photo
    Last week, I repaired the deepend light in the same manner I did the shallow last summer. Here's a pic of thre repair. Read the previous post for info. Seems to work pretty well!
    Jun 2012
    Houston, TX
    39
    Thanks for this post. I'm about to do this epoxy work on my leaky pool light.
    Bobbystone
    Guest
    Good luck. The fix is still good 2 years later!
    Jun 2012
    Houston, TX
    39
    Thanks, good to know. I epoxied the light cord last week with the same gflex epoxy (using the top of a bleach container as the mold). I reassembled the light with a new rubber seal today and let it run for a couple hours. Everything seems to be working great. Thanks again for the original post.
    Bobbystone
    Guest
    In an update, I used the G-Flex epoxy last year to try to plug up leaking joint where the skimmer boxes inlet meets the tile. I cut a 1" strip of lightweight fiberglass cloth and pasted it in with the g-flex. Then dabbed in some more g-flex where needed. It's still holding strong!
    Wow! This blog is a great find! I had this same exact problem with my Pentair light and thought I was going to have to pull cords and all that. I had a two part epoxy syringe applicator (water proof after it sets). I let the light dry out for a day in the hot sun. The next day I injected the epoxy between the gasket and the cord. Then I built a mold around the base of the gasket with aluminum duct tape up to a 1/4 inch above the gasket around the cord. Then filled that with the epoxy. I let it dry for two hours. Presto! the light has been working for two days now and no signs of water against the lens. I'll give an update in of couple of months to see if I did it right. Thanks Bobbystone.
    Poolio7
    Quote Originally Posted by Melt In The Sun View Post
    Count me as another one. Just got my G/Flex, fingers crossed. I won't be able to know for a while if it worked or not though since my light would always super slowly fill up with water over the course of a season. Thanks to the OP for the tip!
    30-35K gal, IG plaster, 1hp single speed pump, 48 sqft DE-filter PAC-FAB NS-48 (96GPM flow rate), spa, currently no heater installed, Barracuda G2
    I am new to pools so please don't hesitate to give me advice and tips, both highly appreciated! Thanks!
    Smykowski's Avatar
    Sep 2011
    3,065
    Threads like these remind me why TFP is so awesome.
    Great posts guys.
    Hi I'm a new guy here and I think this is what I'm looking for. I replaced the gasket on my light and got it back in but now there is water in there again. The light still works but the water bugs the you know what out of me. I'm going to take it all out again, drain it and hold it under water to see if I can tell where the water is getting in. If it's getting in back at the cord I will try this epoxy fix. Good post and thanks for the suggestion.
    Milwaukee WI, USA
    35K gal IG vinyl, 1.0 HP Haywood pump
    Sta-Rite Cristal-Flo T-240BP-1 Sand Filter
    Polaris 380
    Just wanted to report back that it worked great, no water in the fixture at all. Thanks again!
    May 2012
    Houston
    6
    I have read your thread and it is very informative. Thank you.
    I have one question, you said, "Before I tightened the retaining wire around the gasket assembly, I turned the lamp on and let it heat up the air inside a bit. I've read a lot about NOT doing this, but my thinking is that a big part of the problem is the expanding air inside the fixture which seems to leak out, breaking the seal and then invite water back in when the lamp cools." I agree that it makes sense to do this and therefore create a vacuum inside the fixture. But, should you do this with a new light since the retaining wire is already tightened and if you do loosen the wire before heating it up should you replace the gasket before you heat it up?
    Thanks, Paul R. Powers
    May 2013
    mid-TN
    102
    I too thought my repair would work too. but since my pool is a 20 year old salt.
    the salt eventually caused the wires to corrode and socket to rust out.
    eventually things need to be replaced, just a part of pool maintenance.
    18X36 Grecian 24400 est., pacfab sand Triton II, 1.5hp AOSmith, clormatic 2
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I'm thinking of giving this a try on my light. I tried stuffing the back full of plumber's putty last year but I think I need to get more serious this time around. Tired of my defunct light taking up residence on my pool deck.
    Isolated Spa - 345 Gallons
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by JVTrain View Post
    At least yours will reach to the deck. The intelligent people that installed my worthless aqualumin light only left enough cord to barely get above the surface.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    I had the same problem. Gasket was fine, but the cord entry was the source of the leak. I applied silicone sealant liberally around the cord entry and that fixed it. Interesting that I'm not the only one.
    Approx. 18'X24' Pebble Tec free form shape.
    Jul 2015
    Frisco/TX
    33
    Have replaced the SAL Amerilite in my pool a couple of times now. Apparently from what I've read, leakage around the cord entry was a common issue with these things. Maddening.
    wjr75's Avatar
    Jun 2013
    IL
    836
    I just replaced mine with a Pentair LED. Had all sorts of GFCI issues with my SAL Amerlite.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
  20. Back To Top    #20
    Cybergy's Avatar
    May 2014
    Whitby, Ontario - Canada
    82
    Wish I had found this thread earlier but I searched for SAM and Pentair, not "Amerlite" - dang.
    So people here are having positive results sealing with a liberal amount of either silicone or g-flex epoxy? I will pick one and apply it liberally before installing when my new Pentair Intellibrite light arrives later this week. I'm leaning towards the silicone, as the g-flex looks a bit more complicated to install.
    I think my original SAM light didn't have enough silicone to seal (pictured here)
    It's a shame Pentair can't make a light that doesn't leak. These steps should not be necessary.
    I'll update my results later on.
    Many thanks to all!
