Thread: Pool pump
    Pool pump
    I am new to this forum so I apologize if this is not in the right area.
    I am thinking about buying a variable speed pool pump. My PG&E power bill is out of control (500-700 a month). I am wondering if buying a variable speed pump would help and if so what would be the best size, kind for me. My pool is 22,000 gallons and it is 5 years old. I do not have solar or a heater and don't plan on getting them.
    I have the following pool pump:
    Sta-Rite, 3/4 HP, KW .75, RPM 3450, model P6E6D-205L (motor model K48K2PA105C1)
    I also have the following pump for the sweep:
    Century Pool-Spa, 3/4 HP, 3450 RPM
    Thanks for your time and thoughts.
    22,553
    Re: Pool pump
    Welcome to TFP.
    The first thing we need to know is what are your run intervals? (how many hours a day do you run each pump)
    You can try running them less if you're running them a good number of hours a day.
    Re: Pool pump
    The pool pump runs 5 hours a day right now. Maybe an hour longer or so if hot out. Sweep runs 3 hours a day. Water looks great an generally only need to add 32 oz acid each week.
    Re: Pool pump
    I hate PG&E
    How much $ per KW?
    1971 San Juan Fiberglass pool 12,000 gallons
    New Pentair Whisperflow 1hp
    New Pentair FNS DE filter 64sq
    All 1.5" piping and no heater
    1 skimmer, 1 main drain, and 2 returns
    22,553
    Re: Pool pump
    At 3/4hp ea, and 5 & 3 hours a day I doubt your pool pumps are contributing significantly to your power bill. A variable speed pump will help but not very much.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Pool pump
    That pump shouldn't draw more than about 1.2 kw and with 5 hours/day, that would be about 180 kwh. Even if you are in tier 4, that shouldn't be more than about $72/month for the pump. The booster maybe $40/month (~100 kwh). Sounds like you have something else which is using a lot of power. AC perhaps.
    Mark
