Thread: heater problem
    May 2009
    Trenton NJ
    497
    heater problem
    I have a 2005 marquis spa (Quest). It sat idle and empty for 2 years. Today I cleaned it up and replaced the filters. The problem is the water will not heat up, also the heat led is not lit. I followed the start up procedure, set all my settings and 8 hrs. later the water was still cold.
    The other strange thing is no diagnostic code. Could it be the heat sensor or heating element or both? Is it a do it yourself project?
    Thanks
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    May 2009
    Trenton NJ
    497
    Re: heater problem
    Well, this morning I checked the water temp. and it was 100 degrees. So the heater works but the LED for the heater does not. Should I have the LED replaced or not bother?
