Thread: Burning out a heater using SWG--eek!
    My above ground, indoor exercise pool just blew out its heater. The Hayward people said the heat exchanger was damaged through the Aqua Trol SWG that were both made by Hayward. Is there anyone else with this issue? My pool guy uses only the sticks for chemical checking and I had heard that Ph issues can cause damage. He swore all was balanced but I now have a broken heater. Now I am not sure about replacing the heater and keeping the SWG or giving up on SWG which I really like....this is annoying and expensive...any help or condolences??? Thanks.
    Re: Burning out a heater using SWG--eek!
    The SWG did not corrode the heater! If anything a SWG, raises the ph to being more basic, not more acidic.
    1971 San Juan Fiberglass pool 12,000 gallons
    New Pentair Whisperflow 1hp
    New Pentair FNS DE filter 64sq
    All 1.5" piping and no heater
    1 skimmer, 1 main drain, and 2 returns
    Jul 2007
    Brisbane, Australia
    874
    is your heater installed before the SWG, after the SWG or in parallel to SWG?
    Jun 2010
    74
    That is the key question right there.
    I have heard many many times that if your chlorine source (SWG, erosion feeder, etc) is setup before the heater, the very-high level of chlorine at that point going through the line will damage your heater.
    * Responsible for the operation of 21 semi-private pools and spas at 11 locations, varying from 1,900L to 20,000L spas and from 13,000L to 200,000L pools.
    Mar 2007
    San Rafael, CA USA
    12,082
    sbnslp,
    Welcome to TFP!
    Please answer Strannik's question as it makes a big difference. The SWG is supposed to come after all equipment, including the heater:
    Quote Originally Posted by Strannik
    As for an SWG increasing the risk of corrosion of a copper heat exchanger:
    Quote Originally Posted by vln
    It is not just a low pH that can increase the rate of metal corrosion, but also increased electrical conductivity from the higher salt level. Though the rate of increase would be small, it could push any marginal heat exchanger over the edge and is why some manufacturers recommend keeping salt levels lower (< 2000 ppm so not using an SWG) or using cupro-nickel or titanium heat exchangers.
    Richard
