Results 1 to 18 of 18
Thread: Finally started build today
    After hours and hours of research, bids, more research, etc...we finally started our build today. Any feedback welcome. Thanks again for everyone's help getting to this point.
    The pool is 16x32. 3'4" to 8' diving pool. Construction is concrete block walls with vinyl liner.
    Pentair WhisperFlo WFDS-4 - Pentair Tagelus TA 100D
    16x32 Vinyl Rectangle 3.5 to 8 ft deep - One skimmer, One dedicated suction, three returns - 2" PVC
    Poolvergnuegen Two Wheel Suction Cleaner - One Poolskim
    Inter-Fab T7 Diving Board w/Edgewater Assy - Four Pentair Deck Jets - Intermatic T10604R
    Circupool RJ45 - Taylor K-2006 Test Kit (purchased prior to learning of the TF-100, unfortunately)
    Aug 2010
    Queen Creek, AZ
    14
    Re: Finally started build today
    Hey CONGRATS!!!!
    12,000 Peanut Pool
    Sand Filter
    Zodiac SWG
    In-ground Pebble tech
    Not sure on pump size
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    cool! Did they use any rebar in those footings?
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    No rebar was used.
    Pool is coming along. Here's latest pic--
    Mar 2010
    Western Australia
    1
    Nice - are you going to concrete fill the blocks?
    I am undertaking a similar project(plunge pool), but will be fully tiling it.
    Keep up the photos!!
    Porter.
    [center:im2v6vxw]Under Construction - Fully Tiled Besser Block Concrete Pool[/center:im2v6vxw]
    Yes, the concrete blocks will be filled with more concrete. We are on hold for a bit due to rain.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Looking good! Are you going to build the steps as well, or use something pre-fab?
    The steps will be formed from concrete. I assume they'll be poured when they fill the walls.
    PB had the 2" pvc dropped off today.
    Build is coming along. If you have time, please also review my post specifically related to the plumbing the "Pumping Station" forum.
    susa's Avatar
    Oct 2010
    Deep South
    578
    looks great!
    a hint:
    when you want someone to look at a specific post, use the URL button.
    steps:
    1. highlight the words that will serve as the link (ie. my post)
    2. press URL button which will surround your words with the url tags
    3. insert an equal sign = at the end of the first url (ie. url becomes url=)
    4. paste the fully qualified link immediately after the = sign (ie. url=http ... )
    Thanks for the suggestion, added the link to the post.
    susa's Avatar
    Oct 2010
    Deep South
    578
    heh.... not quite, had you followed my small tutorial, the link would have been invisible and clickable from your words .... my post.....
    Fixed. Thanks again.
    TFP_wanna_be's Avatar
    Orlando, FL
    129
    Looks great!! I really like the steps!!
    My Intro Page: tfp-wanna-be-checking-in-t27499.html
    20K Gal IG Pool - Resurfaced 11/14 w/ Super Blue Diamond Brite
    I test with TF-100 and SpeedStir
    1.5Pentair / 36sq DE filter
    Polaris 380 (love this thing)
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    please keep updated with pics. How do they hang the liner??
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    It is a little hard to see, but if you look directly below the coping brick you will see a white strip. That is an aluminum track type of material, which i assume the liner will ultimately plug into.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Hey how has this pool progressed. Any finish pics?
