Thread: Increasing the TA
    Sep 2010
    Roatan - Bay Islands
    35
    Increasing the TA
    I am just filling up my pool and these are the initial values :
    FC : 3
    CC : 0
    PH : 7.5
    TA : 50
    CYA : 0
    Do I need to increase my TA ? And if this is the case, do I need to use Baking Soda or Borax , and how much ( 10k gallons ) ?
    Also, is it recommended to use an initial dose of BORAX anyhow ? How do I check for borates ? I do not see the test available in my TF 100 XL kit.
    Pakal
    _________________
    10,000 glns bean shaped inground plaster pool - Pentair SD60 sand filter - Pentair 3/4 HP pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Increasing the TA
    TA can be raised with baking soda. If your PH is stable at 7.5 with TA at 50, just leave it alone. You do need to get some CYA in your water though
    Borates are a nice to have, but not neccessary. I use them, but again optional. To measure borate levels you need borate test strips.
    Sep 2010
    35
    Thanks for your reply. CYA is on his way up, I'll test in a week. Was thinking of some Borax as a one time dose to stabilize ph and control algae, but dunno how much to put in my 10k glns pool.
    I guess I can easily assume that my borates level is now zero.
    P_
    _________________
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by pakalrtb
    P_
    That's correct, unless you have added any you can assume it is zero. You can use poolcalculator.com to figure out hoe much is needed to get to 50ppm. You'll need Muratic acid as well.
