Thread: Removing polaris connector
    Hi,
    The connector of my polaris broke inside the pool wall. Apparently someone glued it into the wall. Any suggestions on how to remove the broken piece without damaging the threads on the wall side connector so I can reinstall my sweep? I think I have two or three returns but the one it was originally hooked up to seems to have the most pressure when returning water to the pool.
    Thanks for any info.
    impvme
    in ground plaster kidney ~15500 gal, Pentair Clean & Clear Plus 240, Whisper Flow 3/4hp, dedicated pool cleaner w/booster pump mod# PB4, pool - 20+ yrs, pump, filter and booster ~9 yrs, Polaris 380 pool sweep(~15 yo).
    SCEADU's Avatar
    Feb 2010
    Atlanta,GA
    68
    Re: Removing polaris connector
    You should be able to get it out with a punch and hammer. Just lay the punch alonside the broken piece and gently tap it until it screws out
    South Central NJ
    3,192
    I doubt someone glued it. If it's calcified, grab it with pliers. If that fails, use a hacksaw blade to cut score lines about 45 degrees apart, stopping just shy of the threads. Break the fitting at the score lines and the fitting should become removable when grabbed with pliers. The fitting's diameter will slightly decrease when being turned, releasing hold the calcium deposit or friction that is preventing it's normal removal. Replace the fitting in the Spring.
    Scott
    Owner of - PoolGuyNJ LLC
    Jan 2009
    Cupertino, CA
    1,966
    Something like this happened to me a while back. Channel-lock pliers did the trick.
    --paulr
    BBB "Intermediate Swimmer"
    Aug 2007
    near the swamp
    806
    channel locks and a putty knife/fan blade big enough to fit in the slot
