Thread: NEWBIE HERE
    Sep 2007
    Ont. Canada
    59
    NEWBIE HERE
    [i]I'm glad to find this great site, We are hiring a contractor to build our 1st IG Vinyl pool, here are the spec 18x32 16,000 gallons, STA-RITE Dyna Glas 2hp pump and System 3 Modular cartridge 300ft2, JANDY Aqua Pure 1400 Generator and 325,000 btu LJ Digital Hot Ignition Gas Heater. Is this a good combination? Comments welcome.
    Dennis
    _______________________________________
    Dennis
    16000 gallons GRAND BEND ig vinyl pool, Sta-Rite Dynaglas 1hp pump and System III modular cartridge filter 300ft2, Jandy Aqua Pure 1400 salt generator, 325000btu LJ gas heater, 2 Pentair 500 watts lights, 4 deck jets.
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to TFP! The comments will be coming from those who know
    Good luck with your pool build.
    Joyce
    You're done SLAMing when:
    Arizona
    924
    They are all good and common brands of equipment, but I don't know specifically about the models.
    Welcome to the group! You've come to the right place to learn how to best take care of your pool.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    You could save quite a bit on electricity by getting a smaller pump and/or a two speed pump. A 3/4 HP full rated or 1 HP up rated pump would be plenty since you don't have any water features (spa, waterfall, fountain, etc).
    Sep 2007
    Ont. Canada
    59
    Thank You for the warm welcome and LION's suggestion.
    Dennis
    Dennis
