Thread: pool salt meters
    Apr 2009
    SC
    26
    pool salt meters
    I have a salt water chlorine generator and think that it's one of the best investments that I have ever made. I'm tired of going to the pool store to have my water's salt level tested. Anyone with any experience/suggestions on a salt water meter that I can buy and do it myself. Do you guys at TFP sell one? Thanks much!
    Bigdog12
    43,500 gal/Heyward 240 sand filter w/ 1hp pump/In-Ground pool/vinyl liner/Jandy SWG
    South Central NJ
    3,192
    Re: pool salt meters
    www.tftestkits.net has strips and Taylor's salt test. I have found the strips to work well enough and are more economical.
    Scott
    Owner of - PoolGuyNJ LLC
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Don't know that I would buy a meter due to expense. You don't have to test salt a lot and using strips or the Taylor kit is all you need. I use the Taylor kit and like it. It will get you to within 200 ppm which is as good as you will ever need.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    susa's Avatar
    Oct 2010
    Deep South
    578
    any opinions or experience on this unit
    am also considering this one, little cheaper
    I do have a cheap (sub 25) test kit from home depot but wanted something more spiffy especially with new pool and all new equipment, SWCG too
    Oct 2010
    Georgia
    317
    The advantage of the Color Q with digital readout, would be great if you are colorblind or partially colorblind.
    Taylor 2006 is 1/2 the price and has greater accuracy on some tests.
    The TF-100-XL uses the same regents as Taylor and is a better value.
    http://tftestkits.net/TFTestkits-TF-100-XL-p54.html
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Apr 2010
    Las Vegas
    173
    Leslie's has a cool one for $120 I'm looking at, Just got my chlorine gen. going. It's a digital wand type made by some big brand, can't remember. They just started used them to replace their old wand testers in my local store.
    20,000 gal. 32' x 17' freeform custom pool, 3ft. shallow - 8ft. deep end, Pentair Whisper flow 2.2 HP WF-6, Purex/Triton Nautilus FNS48 DE filter, 2 Intex Chlorine Generators (retired) SR Smith Rouge Rapids curved slide, The Pool Cleaner 4-wheel model w/Hayward large leaf canister. Tightwatt pool timer Spa: Beachport 5 person/350gal. Wishlist: move Neiko Tools pump to slide, solar system, Fountain, Automation. http://www.poolcalculator.com/
