Results 1 to 9 of 9
Thread: IntelliChlor add salt red light is on with plenty of salt
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    My Pentair IC40 has the red, add salt, light on steady and I have taken two readings with the Taylor Salt Test Kit that says the salt is at 3600 (18 drops). Any ideas what I can do to correct this issue?
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Dec 2009
    Central Massachusetts
    2,690
    Re: IntelliChlor add salt red light is on with plenty of salt
    If you have an Easytouch, what does it say the salt is?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Apr 2010
    Fleming Island, FL
    431
    Don't have an Easytouch, my pool guy gave me the cheap one that doesn't show the salt level. I only have the one salt light that will be either green, red or flashing red. Mine is solid red.
    Carlos
    Apr 2010
    Fleming Island, FL
    431
    Seems to still be producing chlorine too, which is confusing. I thought if the light was on it would not produce chlorine.
    Carlos
    Dec 2009
    2,690
    Quote Originally Posted by benavidescj
    Seems to still be producing chlorine too, .
    How did you determine it is still producing chlorine?
    Apr 2010
    Fleming Island, FL
    431
    Not real scientific, but I haven't lost any since yesterday. Chlorine is 4.5 ppm and I have not added any. I would think that if by tomorrow it still is up around 4.5 ppm I could assume it is producing.
    Carlos
    Jun 2010
    TT
    85
    Don't want to sound like "it" but...
    Have you tried turning it off and on again since adding the salt?
    Took me a few minutes to realise that after I saw the red light and added a ton load of salt I had to power cycle for it to re-read the salt content.
    Apr 2010
    Fleming Island, FL
    431
    I added salt (two 40 lb bags) about a week ago. Since then it has turned off and on several times with the timer. I am going to try cleaning it in the next couple of days.
    Carlos
    Apr 2010
    Fleming Island, FL
    431
    UPDATE: I cleaned the cell, which really did not look dirty. I also unplugged the cell from the power center and plugged it back in while the power center was off (not sure this would do anything). Anyways, all is better, reading good now.
    Carlos
