Thread: Water Tubes: Where and What to buy?
    Hi Everyone,
    I need help with buying some new water tubes for my winter leaf cover. I notice that online stores measure them in gauges. But I thought plastic was measured in mils? Anyway, the stores tout the higher gauges as being thicker and better. However, I thought low gauge number were thicker,(as in sheet metal). I would appreciate any advice on what type, gauge and where to purchase water bags. Also, is there any suitable product that can replace the water bags?
    Thanks again,
    Webfeet
    20 x 40 Grecian inground liner pool
    Re: Water Tubes: Where and What to buy?
    This may need to be moved to EVERYTHING ELSE, under the EQUIPMENT header. I think I should have posted it there to get more exposure. Please move it, if possible.
    Thanks again,
    webfeet
    22,543
    There have been several discussions lately about water tubes and what could be used to replace them. You can use the Google search at the bottom left of each page to search for them. One idea that I liked was using PVC pipe filled with water connected together to make a ring around the pool.
    South Central NJ
    3,192
    Actually, I like the single cell 8' cheap ones. The thicker ones dry out and birds pop them just as easily. Longer ones lose more holding power when they pop.
    Dual cells, when one of the cells pops are useless, regardless of length.
    Scott
    Owner of - PoolGuyNJ LLC
