Results 1 to 7 of 7
Thread: Got my New test kit! Heres my results.
    Aug 2007
    Southern California
    9
    Hey guys. Got my new Taylor test kit today. How are my results looking?
    FC 1.4
    CC 0.2
    PH 7.8
    TA 100
    CH 290
    CYA 30
    Its a 1500 gallon plaster pool with a Polaris SWCG. I know I need to bring the Chlorine up and the PH down a bit. Any other advice? Thanks.
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome here ... you sound like you know what is going on
    If you need any help 'tweeking' things, just ask! Again, welcome to TFP!!
    Luv& Luk
    -Ted
    Looking good. FC up, PH down, just as you said, and all will be perfect.
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    489
    how about the CYA - doesn't he need to double that? I'm not sure about Polaris SWG requirements.
    Brian
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    Aug 2007
    Southern California
    9
    Thanks for the quick replies everyone. Yeah I'm not sure about the CYA. The pool has been filled for almost 4 weeks now, and between me and the start up guy, I think about 4 lbs. have been put in. I have read (maybe somewhere her) that you need to have higher CYA with a salt water chlorine pool.Not sure though.This is my first pool so I'm still learning.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Most SWCG manufacturers do recommend higher levels of CYA. For example, the manufacturer of mine recommended a CYA level between 70 and 80. This info should be in the manual for the unit, or on the manufacturer's website.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Polaris doesn't recommend a specific CYA level, they just say "stabilizer (cyanuric acid) at levels appropriate for the regional climate". Nothing will go wrong at 30, but the cell will last longer at higher CYA levels, say 60-80.
