Thread: Algae and then a hard scale like compound
    I have been having a rough time with algae this year...Now that the season is closing I am ready to close my pool but I had one more huge green algae outbreak....I removed my walk up ladder and added a whole bottle of algaeside to kill it and vacuum to waste....The water is clear and the algae dead but a scale like compund is completely covering my above ground liner....I have attached a picture of where the stairs were removed to see how bad it is....How can I remove this? Should I mess with it before closing or will I be able to remove it next year? The only thing that will remove this stuff is a green scotch bright pad - Not good for a vinyl liner....Help!!!!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Algae and then a hard scale like compound
    Welcome to the forum
    Post a full set of numbers and let us know how you got them. This will help folks figure out the problem.
    Have you been to Pool School yet?
    You're done SLAMing when:
    22,537
    Welcome. As Butterfly said, a full set of test results will help greatly.
