Thread: black algae options to kill it.
    Jan 2010
    Claremont california
    100
    Hello,
    I have a black algae problem. It has been getting better but the black little spots (1/4) inch will not go away.
    This is what I have done:
    1. Shock to 50 FC
    2. Brushed with stainless steel brush
    3. Emptied 30% of water from pool.
    4. Ran to pump 24 hours for two days.
    I am getting very frustrated but what should I do? Should I shock back to 50FC?
    Please advice,
    The details about my pool: PLASTER 30K NONE SALT WATER POOL IN GROUND /PH 7.4 CYA 80 /CURRENT FC 25/ ESTIMATED WATER VOLUME IN POOL IS ABOUT 18K GALLONS.
    I thank you so much for any advice,
    George from Claremont California.
    22k plaster pool kidney shape. Pentair 4000 de series 48 ft. 2 SKIMMERS, 2 drains (pool and spa), 3 returns (2 pool and 1 spa) gas heater and pentair intelliflow , Underwater pentair light.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: black algae options to kill it.
    Maybe treating the spots directly for example using a tri tab as a scrub pad.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    PH 6.4 is that a typo? If not you should raise it to 7.4 with borax asap. Are you sure it is BA? Try rubbin the affected area with a trichlor puck and see if it subsides, if so we'll know it's in fact organic and not metal staining.
    Jan 2010
    100
    Quote Originally Posted by dmanb2b
    Yes, the 6.4 is a typo. The actual value is 7.4.
    I will jump in to the pool and see if the actual black spots are BA.
    Thanks for your help!
    George
    Jan 2010
    100
    Quote Originally Posted by X-PertPool
    Why I did not think of that?
    George
