Thread: Aquabot Turbo T not moving
    Jun 2010
    Elkridge, MD
    104
    Hi all,
    A few weeks ago, I ran over the power cord to my Aquabot Turbo T power supply. My Aquabot, which I purchased this year and never had any prior problems with, sat for a couple of weeks while I took care of getting the power cord replaced. Now I put the thing back in the water and...it just sits there with water and air coming out of the top. It has only moved maybe ten feet, if that, since I put it in the water a while ago. Does anyone have any guesses what might be wrong? I already took the bag out of it and cleaned everything inside as best I could...
    Thanks in advance...
    32 x 16 20,000 gallon inground vinyl. Pool Genie filter. BBB seems to be working well so far despite high CYA. Aquabot Turbo T which I adore.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Aquabot Turbo T not moving
    Aquabot owners?
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    I have had my Aqabot for four seasons now, but I have never had that problem, so I pulled out my troubleshooting guide and looked up your problem. Under "Pumps Water, but Does Not Move or Moves Slowly", it gives three things to check: 1. Remove any forgeign matter that may be obstructing the Drive Tracks. 2. Check Drive Belts and Tracks. Make sure they have not slipped out of place and they are not loose. 3. Observe Drive Pulley, if it is not moving, contact Customer Service. You can also go to www.AquaProducts.com for the most up-to-date troubleshooting information. Good Luck. I sure do enjoy watching my Aquabot do my work for me!!
    18,000 gal, 18x32 IGP, vinyl liner, 3 to 5.5ft depth. One inlet/skimmer (Aqua Genie), one main drain. Hayward Pro Series Sand Filter w/filtration rate of 20 GPM/FT, Two-Speed Pentair Whisperflo 1 HP pump, Natural Gas Hayward H200 pool heater, Aquabot T2 (200 Series) Robotic Pool Cleaner (my best friend), Automatic Electric Pool Cover (2nd best friend).
