Thread: Is this calcium scaling?
    East Texas
    18
    New pool: filled in July. Salt water. I've been having his issue for some time now. I get this white ring on the flagstone edge of my tanning ledge and along the rocks in my waterfall and on the rock ledge. The white stuff occurs at or above the water line and I see none on my pool tile or on the flagstone or rocks that are in the water.
    Pretty much since the pool opened, I've been having to add about 40-48oz of MA every other day to keep the pH down; if I miss a day of testing and let it go 3 days, pH is always going to be over 7.8. My TA is 90, and my CH is 210.
    Is this white stuff calcium buildup? If so, how do I get it off and how do I keep it from coming back? and Finally, is this adding of MA every other day normal??
    22,700 gallon, 16x38 rectangular gunite pool with midnight blue quartz plaster, SWG (Intellichlor IC40), Pentair VS pump, Pentair Clean & Clear Plus cartridge filter, lakefront property
    Guest
    Re: Is this calcium scaling?
    Yes, keep your PH around 7.2 - 7.4
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,652
    Maybe its' just your rocks melting from all the heat we've had in East Texas this summer and lack of rain! But yes, that's what it looks like.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Yes. And I bet your coffeemaker, showerhead, and shower tile all have a similar crust.
