Results 1 to 14 of 14
Thread: Taz vs. Pool Store Test
    Taz's Avatar
    Jul 2010
    NE FL
    80
    Just for grins I thought I'd post the results of my testing using the TF-1000 kit compared to the testing done by a local PS (my builder)using the BioGuard "Alex" strip reading system.
    [table=1:2p8n5y7v][tr:2p8n5y7v][td:2p8n5y7v][/td:2p8n5y7v][td:2p8n5y7v]Taz …...[/td:2p8n5y7v][td:2p8n5y7v]Pool Store[/td:2p8n5y7v][/tr:2p8n5y7v]
    [tr:2p8n5y7v][td:2p8n5y7v]PH[/td:2p8n5y7v][td:2p8n5y7v]7.5[/td:2p8n5y7v][td:2p8n5y7v]8.5[/td:2p8n5y7v][/tr:2p8n5y7v]
    [tr:2p8n5y7v][td:2p8n5y7v]FC/TC[/td:2p8n5y7v][td:2p8n5y7v]6.5[/td:2p8n5y7v][td:2p8n5y7v]5.5[/td:2p8n5y7v][/tr:2p8n5y7v]
    [tr:2p8n5y7v][td:2p8n5y7v]CC[/td:2p8n5y7v][td:2p8n5y7v]0.0[/td:2p8n5y7v][td:2p8n5y7v]0.0[/td:2p8n5y7v][/tr:2p8n5y7v]
    [tr:2p8n5y7v][td:2p8n5y7v]TA[/td:2p8n5y7v][td:2p8n5y7v]75[/td:2p8n5y7v][td:2p8n5y7v]45 (adj. TA)[/td:2p8n5y7v][/tr:2p8n5y7v]
    [tr:2p8n5y7v][td:2p8n5y7v]CH[/td:2p8n5y7v][td:2p8n5y7v]400ish[/td:2p8n5y7v][td:2p8n5y7v]337[/td:2p8n5y7v][/tr:2p8n5y7v]
    [tr:2p8n5y7v][td:2p8n5y7v]CYA[/td:2p8n5y7v][td:2p8n5y7v]65[/td:2p8n5y7v][td:2p8n5y7v]95 (there’s no way )[/td:2p8n5y7v][/tr:2p8n5y7v]
    [tr:2p8n5y7v][td:2p8n5y7v]NaCl[/td:2p8n5y7v][td:2p8n5y7v]3900[/td:2p8n5y7v][td:2p8n5y7v]3170[/td:2p8n5y7v][/tr:2p8n5y7v][/table:2p8n5y7v]
    I'm going to drop the pump run time down from 10hrs to 7hrs now that we aren't really going into the pool much (78 deg - time to get a solar cover). That will drop the FC down a little. Everything else is pretty close.
    Thoughts?
    30' x 15' kidney shaped, 3.5-5.5 ft deep, wet-mix shotcrete inground, AutoPilot Digital SWG - RC35/22 cell, 36" main drain, 1 skimmer, 4 returns, Dyna-Pro 1 HP, Sta-Rite 2 (PLM100) filter, Polaris 360 cleaner, Marbletite (Marquis/Bluestone), Screen enclosure
    30,426
    Re: Taz vs. Pool Store Test
    Good morning, taz,
    Another really good post to remind people to always trust their own testing. pH is normally pretty decent with test strips but that one is absolutely unusable. CYA always seems the worst and completely unreliable with strips.
    What did you use to test for salt? What did they use?
    22,551
    Ok I'm jealous!!! How come all I got was a TF-100??? I want a TF-1000! What's up with that Dave? Do only the "special" folks get a TF-1000??? Sorry just joking around a little. Couldn't help myself.
    I'm surprised at the pH, that's the one thing they usually are pretty close on. Just goes to show you that every test performed by the pool store is suspect.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    May 2008
    Virginia Beach, VA
    84
    Wow, again reminds me to be thankful for this site and a good test kit.
    Were they recommending that you buy $100 worth of "PH DOWN"? Or did they scold you for having your FC too high??? I can't imagine how much that would have messed things up if you hadn't been troublefreepool'd.
    Steve
    28K IG Vinyl lined pool - 1 skimmer, 2 returns
    Hayward DE 60sqft filter; Polaris 280 vacuum with booster pump
    Mar 2010
    Spring, TX
    1,082
    I want a TF1000 as well. That must have some huge bottles of reagants haha.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    I've got that beat easy. I recently dumped in an extra heaping helping of bleach to cure what I THOUGHT was possible algae which turned out to be dang fine dirt. Levels were falling off shock level. I tested at FC at 11 ppm----------and 30 minutes later---------THEY came up with 3.2 for FC. That's gotta be a new world record for FC loss over a 30 minute time span. How on earth is that remotely possible?
    How much to upgrade to the TF 1000 again?
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,063
    Hey Taz, I would not trust readings from a pool store now that I have the TF-100. I too saw a huge difference in readings. I remember everytime I went to the pool store I ended up spending $100. Now I save that money every month and use that extra money to buy adult beverages
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Taz's Avatar
    Jul 2010
    NE FL
    80
    I got distracted talking to the builder but I 'think' it was a separate strip. I used the averaged reading on the pool pilot digital.
    Taz's Avatar
    Jul 2010
    NE FL
    80
    The TF-1000 requires purchase of the TF-100. It magically transforms into the TF-1000 when you get and follow your pool advice from this fine site!
    Taz's Avatar
    Jul 2010
    NE FL
    80
    Quote Originally Posted by Brentr
    Brent - I figure it doesn't hurt to get it tested - I needed a case of MA & they sell it cheaper than any place I've found.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,063
    What is the price? I get mine at HD or Lowes.
    Nov 2009
    Indialantic, FL
    323
    Do you have Pinch A Penny up in JAX?
    Local Lowes pricing = $10.72 for 2 gallons of MA; Pinch A Penny pricing = $4.19 per single gallon (or $8.38 for two). And yes, same strength.
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    Nov 2009
    Indialantic, FL
    323
    Do you have the Pinch A Penny pool store chain up in JAX?
    Taz's Avatar
    Jul 2010
    NE FL
    80
    Martin Pools - On sale for ~$15 for 4 gal.
