Thread: IMPower
    IMPower
    Anyone used one yet or is this brand new?
    Seems to have a lot of the power saving advantages of the Intelliflow and a huge price savings. Now you don't get the fancy flow monitoring/constant flow but you also save a lot of money.
    Thoughts?
    How much power savings with the permanent magnet motors over a conventional 2 speed? I replaced my single speed 1.5hp pump with a dual speed that almost runs all the time on low speed. How much electricity is saved on low speed with a permanent magnet motor?
    http://www.a1poolparts.com/-strse-3065/ ... Detail.bok
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: IMPower
    Using the CEC Curve-A as a reference:
    Intelliflo (PM motor): 130 watts @ 22 GPM & 1000 RPM = 10.15 gallons/watt-hr
    Tristar (induction motor): 169 watts @ 22 GPM & 1035 RPM = 7.37 gallons / watt-hr
    WFDS-24 (2 speed induction): 370 watts @ 31 GPM on low speed = 5.51 gallons / watt-hr
    A 25% difference between the Intelliflo and Tristar seems like a big different but absolute wise it is less than 40 watts. Over time it might make a big difference but it depends on what you pay for electricity.
    Unless you can compare that motor with a wet end to the above pump's using the same test setup, you really don't know for sure what you are going to get.
    Mark
