Thread: What do you do with the left over chlorine in the LQ?
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    Going to close next week and just wondering what you all do with the water and chlorine left over in the LQ when closing? I want to bring the unit indoors for winter. I was thinking since I haven't shocked yet maybe I could crank the LQ wide open for that, but even still I'm sure there will be chlorine left in there (as well as the water on top of the chlorine I'll have to get ride of).
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    30,432
    Re: What do you do with the left over chlorine in the LQ?
    You should be able to use it to shock the pool.....any reason why not?
    flyboy320's Avatar
    Jul 2009
    216
    Ya I think I will. But there will be lots left in the LQ even when I shock. I didn't realize how little you need when it cools off for the season, and I had just filled it about a week before the hot weather ended, so there is still lots left in it.
    30,432
    I would be cautious about exceeding your shock level by too much. Probably 30% above shock is OK but keep in mind it will stay in your pool a good while and take a good while to be consumed down to normal.
    I would consider elevating the FC now and holding it up there until you are ready to cover it.
    22,553
    Here's what I do. Run as much bleach out of the LQ as I can then block off the fill line and remove the outlet line from the float valve and lower it into the LQ all the way to the bottom. Turn on the pump and open the flow valve wide open. It'll completely empty the LQ in a little while. Don't leave it too long as you don't want it to run dry and suck air into the pump.
    If you have an almost full charge of bleach in the LQ you should run it above normal, as Dave said, until there's about enough left to shock the pool.
    flyboy320's Avatar
    Jul 2009
    216
    Thanks guys, as usual, much appreciated
