Results 1 to 16 of 16
Thread: Does liquid chlorine go bad?
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Hi Everybody~~
    DH just told me that our 12% liquid chlorine will go bad--that it has a finite shelf life.
    We keep 3 or 4 jugs of this around, stored outside, just in case of a power failure or whatever. Now he tells me that it is not like Clorox. It has a shorter life.
    He says that bleach is better--it is 6% -ish and is more stable, and therefore it lasts longer on the shelf, but the fact is that we like to be able to buy something from our neighborhood pool store occasionally to keep up a little patronage/relationship going, so we buy some of the liquid chlorine....
    Yes, I am lazy, and I have not searched our site for other postings on this; it's been a long day in an already too-long week.
    Any quick short comments? Thank you very much!
    Weary Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    Re: Does liquid chlorine go bad?
    Yes, it will degrade over time. The same goes with 6% as well.
    1971 San Juan Fiberglass pool 12,000 gallons
    New Pentair Whisperflow 1hp
    New Pentair FNS DE filter 64sq
    All 1.5" piping and no heater
    1 skimmer, 1 main drain, and 2 returns
    Feb 2008
    Denton, TX
    5,061
    Typically, the higher the initial concentration of sodium hypochlorite, the faster it will degreade. So...12% loses strength quicker than 6%, and so on. How it is stored plays a large part in this too. Higher temperatures speed the degradation process.
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Good grief!
    So when I buy this 12% chlorine, or Clorox bleach at some store with bad stock rotation, I have no idea how fresh or how old it is. Darn!
    Lana
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    So lastly,
    What should I do with 4 jugs of 12% chlorine that I have had sitting outside in the glorious North Carolina summer? I guess I will bring it in for the winter and consider it compromised yet not a total waste.
    In the future, I think I will keep indoors future purchases of Clorox, downstairs in the cooler guest room amidst the fresh towels and fancy guest soaps. (again, fatigue affecting my strange sense of humor)
    Thanks everybody. No matter how much I learn here, a lot can slip by. All the more reason to stay active and tuned-in to what is on the forum.
    Thank you!
    Lana
    Mar 2007
    San Rafael, CA USA
    12,082
    Though the half-life of chlorine depends a lot on its quality (since any metals in the water will much more quickly degrade the chlorine), the chart at the bottom of this page shows the half-life of chlorine at various concentrations and temperatures. Roughly speaking, 12.5% chlorinating liquid has a half-life (will get to 6.25%) of around 75 days at 90ºF, 106 days at 85ºF, 156 days at 80ºF, and 231 days at 75ºF. So you can see that it is very dependent on temperature (which is over both day and night).
    6% bleach will last around 3-4 times longer with a half-life (will get to 3%) of around 294 days at 90ºF, 420 days at 85ºF, 617 days at 80ºF and 914 days at 75ºF.
    So if you store your bleach at room temperature, it can last for many months if not years, though there will be some degradation. I know we have some very old Clorox Regular bleach in our laundry room that is still very potent. Chlorinating liquid left outside, especially if heated by the sun, will degrade much more quickly. You generally want to use it within a month or two and certainly can't keep it for an entire season unless you kept it artificially cool.
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Once again, thank you for your help, links, and information! I very much appreciate it.
    Lana
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Perfect idea. Buy your bleach in bulk then freeze it in ice cube trays for long term storage then when pool season hits you can just toss the little bleach pops right in the water for easy chlorination! lol
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    I keep cal-hypo on hand for emergencies. I buy it in the biggest buckets I can handle and it will keep a long, long time.
    Like you, storing bleach is an issue when it gets hot outside. Not a problem in fall, winter, or spring, but summers at 100 degrees is hard on bleach. Was it stored in a hot warehouse before I got it? Just how hot is it in that shed outside in the sun? The garage was at 100 degrees, shed could be hotter.
    I am planning to try to switch to cal-hypo and pucks when possible in the heat of the summer, jumping back to bleach in fall.
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by anonapersona
    I asked about this at the pool shop where I get my 12.5%. What the guy told me is, they use it in their own pool service business, and get two deliveries a week. He also said the plant is relatively nearby, it's probably only 1-2 days old when they get it.
    I have 90F+ days routinely where I live. Earlier this summer I did a fairly careful measurement of the last jug in a batch of 12.5% I'd bought about 6 weeks earlier; it was down to about 9.5%. I do keep it outside, but in the shade.
    I would expect that the rate of degradation slows down as the concentration goes down; that is, after your 12.5% degrades to 6.25% (a few months outside in the summer?), from that point on it should last as long as fresh 6.25% bleach. The only reason that would be true is if degraded 12.5% is somehow chemically different from fresh 6.25% in a way that affects the stability of the remaining hypochlorite.
    --paulr
    BBB "Intermediate Swimmer"
    Mar 2007
    San Rafael, CA USA
    12,082
    It mostly works the way you described where the rate of loss is faster at first and as the concentration drops the rate of loss slows down. The rate of loss varies very roughly as the square of the concentration, so it's not linear.
    Jul 2015
    weston/wi
    17
    Interesting. I have 12 bottles of 12.5% that are dated 5/09/2016 on the bottle. They have been sitting in my garage for over a year. I live in Central WI.
    I did a CL test and it was 4.5. Added 4 cups of 12.5% and did a CL test 40 mins later. It was 7.5. I have a 14,435 gallon pool. I took the water sample from the opposite side of the pool that I added the CL. I thought this stuff would have lost its kick after a year in the garage. Guess not.
    I know my initial measurement was accurate because yesterday the CL was 5.5.
    Granted Central WI gets warm in the summer, but the garage floor probably doesn't ever get over 75F. In the winter the garage hovers just around freezing. The garage doors are closed most of the time.
    24' round AGP, 14,600 gallon, Resin/Steel Wall/Vinyl Liner, Hayward Sand Filter 1 HP Pump
    Aug 2016
    Las Vegas, NV
    21
    Quote Originally Posted by waynetang View Post
    So you're 12.5% actually increased in strength by 30-40%? 32 oz. increased 14,435 gallons by 3PPM? Huh? After a year? What? Something doesn't add up.
    16,000 gallon in-ground, plaster
    Jandy 460 Cartridge filter
    Pool Cleaner
    Taylor K-2006
    JesseSchmidt's Avatar
    Jun 2015
    Fairfield Twp, OH
    206
    Quote Originally Posted by troymeboy View Post
    Maybe they meant 4 quarts which would make it the equivalent of about 5.25%. That makes a lot more sense.
    26k Gal IG vinyl, Hayward Super 1HP, Hayward Pro Series S244T Sand Filter, TFTestkits TF-100 w/ Speedstir
    Links: TFPC for Beginners / ABCs of Pool Water Chemistry / GETTING STARTED / PoolMath / SLAM / TFTestkits / Chlorine/CYA Chart
    Jun 2017
    Vilonia
    1
    The bleach I buy has a date code imprinted just above the label. It lists the year and numerical day of the year the bleach was produced (or bottled). It will read something like 17105. Which is roughly (counting 30 days per month) about the middle of April. There's other info on there, also, relating, I think, to the location of production.
    Jun 2017
    AZ
    56
    I found this article today about how liquid chlorine tested from retailers at least in my part of the world, showed significant degraded chlorine levels in the product on the shelf so this gives you pause about the real strength of the liquid chlorine intended to sanitize your pool. i want to convert but is loses punch after leaves the manufacture at which time had it's stated potency and then you add home storage.....
    Quote Originally Posted by Lana537 View Post
    Hi Everybody~~
    Weary Lana
