Thread: SWG Control Panel Problem - Amp reading drops out after 40 s
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Hi Guys I hope you can help.
    I have a 3 month old Goldline Aqua Rite. It was running well until I noticed the FC was 9 and I wanted to lower the output% to 70%. when I did this about 40 seconds latter it stopped generating and the check salt and check cell illuminated (not flashing).
    also my SWG was reading 4400 salt level before and now it read 2,200
    I tested my salt with a Taylor salt kit and it was 3,600
    I noticed the amps drop to zero, instant salt drop to zero and the main salt reading dropped from 2200 to zero.
    I don't know what is going on. I'm really frustrated.
    Aquatica's Avatar
    Jun 2010
    Nassau, Bahamas
    514
    Re: SWG Control Panel Problem - Amp reading drops out after 40 s
    ok I recallibrated the instant salt level and set it to 88% and no drop out. everything is back to normal. however I will check it again in a few minutes.
    could it be that since the control panel was reading 4400 instant salt level and I had the % to low like 70% that it caused the problem?
