Thread: ph level at closing on AGP
    I am a newbie this year and am closing my AGP for the winter. However, I have run into 2 issues. One, I cannot get the fitting off of the return to add the plug. The fiting has 2 slots. Is there a special tool to remove this. I am worried about breaking the fitting.
    The second issue is the pH level. I have shocked the pool (2 lbs shock and one bottle of liquid chlorine) and I added the algecide (Polyquat 60). However, my reading shows a low ph level. The Chlorine is at shock level and everything else looks good but the ph is low. Is this an issue for closing?
    _________________________________________________
    Above Ground Pool - 27' round
    Hayward Pump
    Cartridge Filter
    Michigan
    Re: ph level at closing on AGP
    Okay.
    A- For the water return on an Above-ground pool: Don't plug it. Instead remove the hose on the other side of the return. This way, water will naturally sip out of your water return. Since the return SHOULD be lower than your skimmer, it will prevent damage to the skimmer (as water cannot reach its level, it cannot freeze there).
    B- I know there's a feeling of urgency, but we need more infos. A low PH betrays the use of Bromine or stabilised chlorine in your pool. The latter being far more common, I believe you use the chlorine tabs (3'' pucks). Your Total Alcalinity should be pretty low too. If it is 0, raise both ASAP.
    You (and we) need to know:
    potens Hydrogen (pH):
    Free Chlorine (FC):
    Combined Chlorine (CC):
    Total Alcalinity (TA):
    Cyanuric Acid lvl (CYA):
    Calcium Hardness (CH):
    C- pH a bit low is not that much of an issue by itself, as in the pool won't fall apart. As what is left of the water will mostly touch the liner, it might form some wrinkles and dry the few plastic component, making them brittle. However, I doubt your pH is only a bit low. Test that alcalinity. If it is anywhere near 0, get some sodium bicarbonate in there ASAP.
    Also, may I know why you shocked the pool and added polyquat? Were there algeas or was it preventive?
    I suspect this was the ''Standard Procedure'' your local pool store gave you. They tend to sell Degreaser and Sodium Bicarbonate too, although remarketed as Pool Protection and Arctic Defense respectively... It is not necessary (get your own sodium bicarbonate) but compensate the low pH brought by the pucks (often blamed on rain) and ''help in spring to remove stains caused by falling leaves and other organics''.
    Skeptical about that last part however.
    Pool: None, and All.
    ''What's really interesting is finding some way to explain some technical concepts with simple terms so that everyone might understand, to vulgarize.'' CaOCL2
    30,408
    How are you testing your pH?
    What were the actual numbers, or were you using strips?
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Yes there is a tool to remove the eye ball... i always plug the return and the skimmer with the proper plugs to prevent freeze damage to the skmimmer. I odnt like draining the pool below the return for the winter.
    Adding ph increaser now with your chlorine level so high may turn the water cloudy.
    Its a good idea to have the ph level in range for the closing but its not gonna cause any MAJOR problems if you wait until spring. Most ppl barely even test their water at the closing so i think youll be ok.
    Here is the tool to remove the eyeball.... most pool stores carry it.. Or should anway...
    http://www.epoolshop.com/SeatRemovalTool.aspx
    Put this in your skimmer
    http://www.poolsupplies.com/cgi-bin/Com ... key=594150
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    Does that Ice Compensator really work?
