Thread: HAYWARD DE FILTER PARTS
    I went to Warehouse pool supply to purchase a new relief valve assembly for the Hayward Stainless Steel Micro Clear DE 720S. SUPRISE THEY DID NOT HAVE IT. I was told to contact Hayward since it was "obsolete". I contacted Hayward and they finally replies today AND the no longer manufacture those replacement parts due to the filter being obsolete AND they have two suggestions. One. buy a whole new DE filter system which means spend a bunch of money.
    2. see if you can find a pool supplier on line or phone local pool suppliers to see if they have any Old parts sitting around. Other than the relief valve I wanted to replace because it keeps eating the o rings there is nothing wrong with the filter and We have replaced the grids with no problems. Has anyone else had problems getting parts for this Hayward filter?
    Oct 2010
    Georgia
    317
    Re: HAYWARD DE FILTER PARTS
    Many discontinued Hayward parts seem to be readily available on-line.
    The part you describe is probably the DEX360AR, but please double check the model and serial number with the supplier before you order.
    Amazon is one source
    Westside wholesale has the valve without the o-ring in stock
    ipoolproducts has the complete adapter assembly in stock with free shipping
    inyopool has most of the parts for this filter in stock
    Poolandspa appears to have all the parts in stock
    poolsinc has it in stock
    mypool has good prices
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
