Thread: New Plaster vs. Solar Heating System
    Jan 2010
    Northern Virginia
    282
    My pool-shaped hole in the ground is going to be plastered and filled this week. I know that I'll have to brush it twice a day for a few weeks to get a smooth finish and have the plaster cure properly, but when I was looking through the manual supplied by the pool company there was a blurb about turning on the heating system.
    It said, if you have a gas heater you have to wait 30 days to turn it on, but if you have a heat pump you can turn it on immediately. I (perhaps wrongly) assumed that you couldn't run the heater becuase the plaster dust kicked up from the brushing would ruin it. I also figured that somehow a heat pump could handle the plaster dust.
    Anyhow, in my pool the only heating that I have is solar so I'm wondering if there's a problem with running the solar heater as soon as the pool is filled or do I have to wait 30 days like I would for a gas heater?
    700 sq. ft./30,000 gal, gunite pool; 48 SF DE filter; 1.5 HP pump; Salt Water Generator; Solar Heat
    22,542
    Re: New Plaster vs. Solar Heating System
    I personally would bypass any ancillary equipment for the first 30 days just to be sure the plaster dust didn't adhere to the internal parts and cause issues down the road. However, with a DE filter (operating correctly), there's almost no chance of that happening and if your solar heater is plumbed correctly you're safe running it.
