Thread: Acceptable overnight FC loss and testing error margins
    saraiks's Avatar
    Jul 2007
    Fremont, CA
    While trying to test for FC loss overnight what should be an acceptable number ?
    I have tested to a 0 ppm to 2 ppm drop overnight without any other issues.
    Can this be considered within the error margin of the test ?
    16,000 G in ground Gunnite (plastered) with attached Spa, Gemini 3 NG Heater, Sta-rite cartridge filter, Aquabot Mark V, TF test kit
    The FAS-DPD test is +- 0.5 on each test. So a difference of 1 ppm is within the error range of the test and can be ignored. It isn't that difficult for there to be 1 ppm of chlorine lost to pollen or leaves falling in the pool. Both of those together could account for a difference of 2 ppm. Still, if watching FC overnight to decide when to stop shocking I would still go an extra day if the difference was more than 1 ppm. It is better to be sure you have gotten all the algae.
