Results 1 to 17 of 17
Thread: Polaris 360 or ThePoolCleaner suction side?
    Dallas TX
    186
    It's been asked many times already (i've done some searching & reading!) but wanted to validate my thoughts with you all...
    Situation:
    33k gunite inground pool
    2 skimmers & 4 wall jets
    no dedicated pressure or suction lines
    Plan to install big 2spd pump & run 24/7 on Low
    Want a pool cleaner which will work with (relatively) low flow
    Debris type: Leaves leaves leaves, acorns acorns acorns, twigs and twigs!!
    I've been running a Dirt Devil pro-V, more or less a Creepy Crawly-type suction side. It gets jammed on the hard stuff like twigs and acorns. Plus it takes pretty good suction to run (current 2.25hp 1-spd). I do have a PoolDevil skimmer, which helps a lot, but getting tired of unjamming the vacuum.
    My thinking is
    1) pressure side will work @ lower pump speed
    2) pressure side will handle the big debris better, not get jammed
    3) pressure side will not introduce all that garbage into my lines & pump basket
    the polaris 360 I can get for around $360, looks like TPC model is around 450. I've seen mixed reviews on the Polaris and nothing but good on TPC.
    Any feedback before I blow a few hundred bucks??
    Thanks!
    33k Gunite, CompuPool CPSC48 SWG, Sta-Rite System 3 DE, 2.25hp dual-speed, POOLVERGNUEGEN Pressure-side
    Dallas TX
    186
    Re: Polaris 360 or ThePoolCleaner suction side?
    whoops sorry, looks like this should have gone into Pool Cleaners forum...
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    How 'bout the pressure-side The Pool Cleaner? Seems to be very highly recommended around here. I know Chem Geek has one; can't remember if Simicrintz's is pressure- or suction-side.
    Dallas TX
    186
    That's what I'm looking at: pressure side, either Polaris (cheaper & better known) or TPC pressure side (more $$ but very good reviews)
    Oct 2009
    3,899
    Ah, didn't get the "TPC"
    Guest
    I have the suction side unit, but the pressure side is recommended for twigs and such, like MITS says. I might be able to help you on pricing if you decide on TPC. Drop me a PM if you would like me to see what I can do (I have Dieter on my speed dial, and I need to speak to him anyway!).
    Aug 2010
    Dallas, TX
    4,052
    Does the pressure side filter anything small? The suction side will use the pool's filter, correct?
    Guest
    Define "small" It is really better for large stuff that goes in the bag. Suction does draw to the filter, correct.
    Aug 2010
    Dallas, TX
    4,052
    Dead, white algae. Suction side on my pool draws through the filter. I have a robot, but the thing died after 2 weeks and I'm still waiting on the replacement. I sweep my pool every day but it's still not making the water clear. My 1954 pool has one skimmer, one main drain, and four returns at the shallow end. Keeping it clean is almost impossible for me at the moment without something in the pool assisting.
    Dallas TX
    186
    Quote Originally Posted by RobbieH
    I'd suggets get yourself a suction-side, it runs the water through the filter & takes care of the fine stuff (assuming your filter is working!)
    30,431
    33k = big pool (and gets a lot of stuff in it)
    Big pool = robot
    Robot = the most cleaning power (but you will have to pay)
    I don't think a suction side is big enough for that pool. Since a booster pump and a pressure side cleaner will add up close to a robot, I'd get a robot.
    Blue diamonds are very good but there are some new ones out that look promising, too.
    Dec 2009
    Central Massachusetts
    2,690
    Get a robot. I only have a 14,000 gallon pool, but I got an Aquabot T with a remote. Only regret is i didnt get it sooner. Just throw it in the pool and walk off.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Aug 2010
    Dallas, TX
    4,052
    Big pool = robot
    I'm going to have to stick with the robot I guess. I suppose my pool is too big to use a suction side. My robot is supposed to be back up and running in just a few days. The power supply died.
    Dallas TX
    186
    Just realized I mislabled the title of the thread (doh) should have read "Polaris 360 or ThePoolCleaner pressure side....
    I've pretty much decided to go with pressure side for it's ability to handle the bigger junk.
    As far as robots go, they look like a pain. Have to store it somewhere, deal with a cord or an expensive battery, throw it in, take it out... bah. I like an automatic vacuum just running around slowly 24/7 keeping the place continously clean. but that's MHO.
    cheers
    Oct 2007
    Parkland, FL
    752
    Quote Originally Posted by acroy
    cheers
    don't forget power supplies dieing, happened twice on the blue diamond, motors dying, that happened at least twice on the blue diamond, etc.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    I have been using pressure-side cleaners for the last 12 years. Currently a Letro Legend II and before that had a Polaris. (no booster pump, ever). Pool details in my sig, below.
    I just went "over to the suction side", LOL.
    I bought and installed a Zodiac Barracuda MX8 suction side cleaner (attaches to one of my skimmers) and it works great, because it is actually vacuuming the pool bottom and it gets ***ALL*** of the fine materials that have precipitated out and are sitting on the pool bottom. We have farm fields nearby and we get a lot of wind-blown dust.
    The Polaris/Letro pressure side cleaners really won't do that. What you are counting on, when it comes to any fine particulates that can't be caught by the bag, is for them to move enough water around in the pool, so that the fine particles can get into a suspended state in the water, and thus can get to the skimmers.
    This is not ideal and the deeper your pool, the less effective it will be, in getting any fine materials into suspension.
    However, large amounts of debris, like palm tree debris that we typically get in the pool during the off season, will easily jam up the suction side MX8, and would also load the pump basket with junk really quickly.
    My plan is to run the MX8 during the months that our pool is open and is, for the most part, clean and free of any large debris (typically April through mid-September, here in Northern CA).
    During the winter months, when my only real concern is picking up large debris that fall in from the trees, etc, I run the Letro, on the pressure side.
    I think that this approach is turning out (so far) to be the best for my situation, of course, your situation may be entirely different.
    Rob
    38,500 gallon free form pool, Gemstone finish by Burkett's, FNS Plus 60, Pentair Intelliflo Pump #011018, Solar, 12 4x12 panels w/Compool LX220....Soon to be adding automation.
    donaldm823's Avatar
    Cape Coral, FL
    147
    My Polaris 360 works well to keep my 30,000 gal pool clean of the big stuff, as long as I "steer" the Polaris part of the time. Working on its own does not get all of the debris, but I am happy with the suction power. My Polaris is not good when it comes to 'fine debris", it just kicks it into suspension.
    I just bought a Polaris 9300 (robotic), but have not yet tried it out so the vote is still out.
    Don SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter, Pentair SWG, Pentair Intelliflow VS pump (11018)
    FAFCO solar panels w/Pentair SolarTouch controller
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
