Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: Travertine
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Travertine
    What can one expect to pay for travertine paver decking and coping? Mat'l cost, I understand labor will vary wildly depending on the location.
    I have "heard" anywhere from $4 a sq ft to $25 per sq foot. Material only.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Travertine
    I'm sure it depends on the look of the stone. Travertine from different quarries will have wildly different colors and textures to it. Think of all the varieties of "granite" at different prices you can see at the home improvement stores! It's the same for any natural stone.
    That being said, are you sure you want travertine? It's the softest stone you could possibly buy for coping/decking. I know some folks have used it, but I sure as heck never would.
    Dec 2009
    Central Massachusetts
    2,690
    Re: Travertine
    Quote Originally Posted by Melt In The Sun
    I'll agree with this. It's really too soft. Even down south where you dont get the freeze thaw cycles, it wont hold up. It looks nice, but I think in the long run you wont like it. It will really start to flake.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Guest
    Re: Travertine
    In agreement with both above. It also can be very slippery.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Travertine
    Tumbled travertine is anything BUT slippery. And seeing how well the colosseum, and several ancient castles in europe (several coastal) have held up... I think it will last the 40 years I want to use it.
    I appreciate the intent of your comments, but was really looking for information on pricing of the product. Its moot now, as I have located an import export company who have sent me samples for travertine pavers at less than $3 per square foot in the quantity I need. Coping is quite reasonable as well. If anyone is interested, PM me and I can forward the company information. They truck to anywhere in the US, but the southeastern US and the East coast are where they concentrate
    Guest
    Re: Travertine
    Sorry, I didn't see anywhere that it said tumbled. I assumed that you were asking about typical travertine. Tumbled is a whole 'nother story.
    That being said, and since I live in the pool world and not the Colosseum, I still wouldn't use it around my pool! Expect it to deteriorate and stain.
    Dec 2009
    2,690
    Re: Travertine
    Quote Originally Posted by simicrintz
    What Bruce said.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Travertine
    it is ~2000 years old. At that rate of decay I think I will be ok.
    But flagstone coping is ok?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Travertine
    here is a link you might find helpful
    http://forums.findstone.com/forum_posts.asp?TID=1782
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Travertine
    Quote Originally Posted by dmanb2b
    That is too wierd. I was reading that exact thing when I got the mail to notify me of an update to the thread.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Travertine
    ahh...I debated whether I should post it or not...but a quick google search never hurt anyone
    Good luck in your pool design!
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Travertine
    I also got caught up in reading about the Burghausen Castle. Over 1000 years old, over 1000m in length, built mostly from travertine. What a beautiful place.
    http://www.schloesser.bayern.de/englisc ... rghaus.htm
    Guest
    Re: Travertine
    Quote Originally Posted by Lershac
    Not for everyone! Mine is deteriorated quite a bit in about 8 1/2 years, but I just have one of my guys go out and replace the bad ones now and then, so it never looks too bad. Would I recommend someone else use it? Not without telling them the same concerns that I've told you!
    Travertine is beautiful. But it has its limitations. If you are willing to accept them, then that is the right product for you!
    May 2009
    Dallas, TX
    784
    Re: Travertine
    Be sure to post pics when you're done so I can drool...
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Travertine
    Great! I appreciate your bringing the limitations to my attention.
    Anyone who has actually bought travertine ( or has some knowledge on pricing ) have anything to contribute to address the question?
    Pricing on the stone seems to vary wildly. Local installers quote it installed at $25 per square foot and up. I have found it MUCH cheaper by going up the supply chain to the ports in Miami and dealing with the import/export folks who bring it in country. They seem very willing to deal, have sent me free samples, and very attractive terms including the right to refuse shipment if it does not meet with approval on delivery. I guess a side benefit of tough economic times.
    Beez, it will be awhile, this is a self-build. A friends heavy construction company is doing the dig, and I will have the gunite shot... everything else will be my project for however long it takes.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Travertine
    Stones vary a lot in their durability, but generally speaking in terms of density and stability of the material, limestone < travertine < marble and all of these are made from calcium carbonate so all are susceptible to acid. If you want the stone to last longer, then have it sealed regularly. As for the old structures made of travertine, the parts exposed to weather do in fact deteriorate if they are more pure travertine, but many of such ruins no longer exist and those that do have thick columns where pitting and flaking may not be nearly as objectionable as in your hardscape/coping.
    If the limestone or travertine is formed with a variety of more durable minerals such as dolomite or petrified organic matter, then it can be far more hardy. Since tumbled travertine is very porous with its many holes, you wouldn't want to use it as a hardscape surface in an environment with freezing winters.
    We have honed and filled travertine in our shower and while it is beautiful, it's a pain to have it resealed every few years and is not the easiest material to maintain. But it's stone, and that's what one expects if one wants to retain such beauty.
    Guest
    Re: Travertine
    Sheesh, chem geek, you just answered the limitations and problems associated with travertine, just like me
    I charge $45.00 a lineal foot. We install it all the time. Quality and location of origin has a huge impact on the material. Remember the old saying "you get what you paid for" as you continue your quest.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Travertine
    ok. I appreciate everyones input. However, the thread focus as intended was NOT to be a debate about the suitability of travertine for pool associated use. I think its pretty clear that like most things, travertine pavers will deteriorate given the time. I can accept that. I can afford the upkeep.
    Can I just say please lets drop it?
    I had wanted to discuss pricing in different areas for the product, but I guess I might just as well have brought up flexible PVC, a pool frog, or a magic sanitizer to have stirred up all this discussion that is not on topic! LOL.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Travertine
    If only I had asked that question? Its like going to get a haircut and the take your appendix out! lol
    Thanks Simicrintz! That would be one of the reasons I negotiated the right to refuse the delivery upon inspection of the material.
    I have not ordered it (yet!) but I have a couple more quotes out to importers working near major ports to see how they stack up. From the samples they sent me, I took them to a local dealer who is a client of mine, and tellingly he asked me to forward him the importers contact information saying it was good stuff. I also took it up the the local university where they promptly broke one into several pieces to test density and structure, and they give me the thumbs up. The also warned me to be especially careful of acid around the pool, and to never let the pool get acidic.
  20. Back To Top    #20
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,058
    Re: Travertine
    We paid $3.00 per sq ft for the extra pavers outside our screened enclosure. This was done thru our PB during construction of our pool build however I think he normally charges @ $4.50 to $5.00 per sq ft. Hope this helps.....
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
