Thread: polaris pop-up keeps popping out
    Well the subject line about explains it. one of the holes where the jets fit in has something wrong with it as I have even tried swapping out the jets. any suggestions are welcome because it only takes about 2 or 3 cycles before it pops out.
    Thanks
    35,000 gal. Plaster, in-ground, Hayward swimclear C4025 cartridge filter,
    5 port polaris cleaning system, Hayward gas heater, spa.
    PhoeniX, AZ
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: polaris pop-up keeps popping out
    So, the fitting is the problem? All of the heads will stay in place if put into another spot?
    Yup. So what can I do, if anything, about that?
    oh and btw I did hear the angels sing and got a glimpse of the heavens, but no such luck on daughter or marriage.....2 outta 4 aint bad, lol.
    PhoeniX, AZ
