Results 1 to 10 of 10
Thread: Southern Alabama pool season over with?
    Jun 2010
    Southern Alabama
    40
    I am new to the area only here for a few months.
    What is the average pool season down here in southern Alabama?
    The water seeems mighty chilly the last week.
    16' x 40' inground Vinyl liner pool. Has a depth APX of 3 1/2' to 8'. Pool also has a right angle APX 4'10' on shallow end. in Southern Alabama. It is not covered with sun on it most the day. SWG. Apx 31k Gallons, Sand filter with 1 HP Pump. Don't know the flow rate.
    Mar 2009
    Charlotte, NC
    539
    Re: Southern Alabama pool season over with?
    Most advise closing once the water temp stays 60F or below.
    See Pool school sections for info specific to you.
    pool-school/closing_in_ground_pool
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    22,548
    Depends on where you are in Alabama. Our water temp is still in the 80's and even though this week has been cool we'll have some warmer days before long. Our water temps won't get to 60ºF until the middle to end of November.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Jun 2010
    Southern Alabama
    40
    We are in Fairhope. East side of the bay little south of Mobile.
    When you are done for the season do you keep it up and have the pump running? or close it for a few months?
    Thanks
    22,548
    I'm just a bit north of Mobile. I left it open all year last year but it's a hassle trying to keep it clean, so this year I plan on partially closing it when the water temp is below 70ºF. I figure that'll be December thru March.
    By partially closing I mean I'm going to cover it and keep the pump running on a timer in early morning hours mostly to prevent freezing damage (not that it's a big concern here).
    Since I have a liquidator, keeping the FC up isn't a concern and I can pull a test sample off the suction line before the LQ connection for weekly testing. I also have an insulated equipment shed so the only plumbing exposed to the elements is the piping where it comes out of the ground going to the skimmer and return.
    Dallas TX
    183
    Pool season lasts till it's cold enough no-one wants to get it
    Honestly, esp in the Southern climes, "closing" the pool seems to invite problems. Chemical balance can get out of wack, motors seize, etc. I suggest turn the pump runtime down to a couple hours a day, keep the water cleaned (manual or automatic skim & vac) and check the water 1xweek or so for pH and chlorine. Then it stays lookin' good all winter, and no hassles 'opening' the pool in the summer: just dive in when it warms up! IMHO....
    cheers
    33k Gunite, CompuPool CPSC48 SWG, Sta-Rite System 3 DE, 2.25hp dual-speed, POOLVERGNUEGEN Pressure-side
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by acroy
    motors seize, etc.
    Thats not true. Ask the thousands that close their pool every fall. The chems dont get that far out of whack either. I close mine every year and open to clear water and near perfect TA and pH, and even 1-2 ppm of FC.
    Keeping a pool open year round is fine, but closing one down doesnt do that much to one if you do it properly.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Dallas TX
    183
    Quote Originally Posted by bk406
    motors seize, etc.
    as I said, IMHO - we can also ask the thousands of pool owners who do have issues every spring opening up - or just watch this board for all the issues! and motors certianly can and do seize up from lack of use and the local fauna building colonies in there...
    North of Houston and I don't close. It is just too pretty to cover, really.
    I keep it tended all winter. Test chems, clean skimmers and pump baskets and Polaris bag. Keep water level right. Freeze protection program in place for Aqualink system, not sure what it does but filter and waterfall come on near freezing temps. Not sure about Polaris, maybe it comes on too.
    Dallas TX
    183
    pump comes on @ freezing to keep the lines from freezing & bursting.
