Thread: Draining below skimmers. No bottom drain
    Aug 2008
    Rochester, NY
    51
    We're having the pool closed on Monday and the pool company asked to have the water drained 2" below the skimmer. We have 2 skimmers, 3 eyeball returns and 2 bottom diffuser returns. We are donning the loop-loc cover and removing the hardware ourselves to save some money. Any special tricks in getting the water level down without using a submersible pump? I was thinking of attaching the vacuum hose to one skimmer, diverting the flow to that skimmer and draining that way. I was also thinking of using some rubber tape to help with the seal between the vacuum hose and the plate that goes into the skimmer. Any help would be appreciated.
    20000 gal IG freeform, vinyl, Pentair Sand Dollar filter, Pentair 2 speed pump, Pentair Intellitouch controller, Pentair Heat Pump. Built 2008
    22,551
    Re: Draining below skimmers. No bottom drain
    You don't need any help with that! You've already got it figured out. That's exactly how I'd do it.
    One trick I like to use is to hook up your vac and then simply run water from a garden hose into the skimmer. This will prevent it losing vacuum and sucking air.
    Good luck.
    Jack
    Mar 2007
    Coastalish 'down easter'
    4,160
    Sounds like you've got it covered
    If you start loosing prime, you can do as Jack recommends and if that doesn't work ask us for other tips
    Fall is a sad time around here as the members close up their pools!
    I hope to see y'all around here over the winter
    Luv& Luk
    -Ted
