Results 1 to 18 of 18
Thread: Copper pipe for gas line 1' underground.
    Hello,
    I'm putting a crushed glass firepit in my backyard, and while the patio is out I'm running a underground gas line to the firepit.
    I was wondering if 3/4'' copper would be alright and meet code appx. 1' underground?
    I plan on pressure testing it to 20psi before I bury it and pour.
    There was some black iron conduit for the old pool light that was rotted out, so I'm not messing around with black iron. I'm assuming PVC is out of the question. I also heard the yellow stuff has to be jacketed with PVC and then you need a crimping type tool for the ends.
    thanks
    Dec 2009
    Central Massachusetts
    2,690
    Re: Copper pipe for gas line 1' underground.
    You need to call the building inspector to find out whats code in your area.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    22,551
    Local code is gonna trump anything we can tell you. If I lived next door I might be able to help. Hum, I might live next door Where do you live?
    Guest
    Get the PE (polyethylene) stuff and be done with it! It does not need to be jacketed with PVC, and the heat tool isn't needed anymore either. They have push type fittings that pass code.
    Iron does what you already know it does, and copper gets pin holes pretty easy (especially in acidic soil), so that is out also. Just like diamonds ( ), PE is forever!
    Dec 2009
    2,690
    Quote Originally Posted by simicrintz
    Simi,
    He still needs to check the code in his area before he does this. PE in my area is not code under concrete and wont pass. Not sure what his code says, but if PE is not allowed, he would have to tear out the patio.
    Guest
    Quote Originally Posted by bk406
    Simi,
    Agreed on checking, although I have never heard of it not passing. Under concrete, with the opportunity of the concrete one day becoming an enclosed room, gas pipe is never allowed. Under sidewalk or driveway it is fine.
    If they will accept iron or copper, they would accept PE. But you are correct to make sure before doing any work
    Dec 2009
    2,690
    although I have never heard of it not passing. :
    Well, you're on the left coast too
    Seriously, the east coast is a lot different on stuff like that. Believe it or not, in places on a commercial plumbing job over 1 story, you still have to use cast iron, no pvc.
    Guest
    Again, true (no hurricanes, no humidity, no bugs; I'm staying here ).
    I assumed that he was talking about buried pipe. We cannot use PE above ground either, and iron on all commercial just like you state. I should have checked his application before I posted
    Dec 2009
    2,690
    I think he was talking about buried pipe, actually. You can use PE, you just cant put it under a patio or slab. A driveway or walk is ok. Kind of depends on what an inspector calls a patio or walk
    Thats why I always recommend talking to them before you run pipe under something you might have to break out.
    Well, the thing is, I don't really want the city to know I'm running it.
    The other thing is I'm pretty competent with copper, and the guy at the fire/grill shop said to just use copper.
    Dec 2009
    2,690
    Quote Originally Posted by tony 340
    Well, I would not want to be your neighbor . Seriously, gas isnt something a DYI'er should do, period. It's fine stuff when installed properly. I've seen houses and whole blocks blown to bits from improperly installed gas lines. Please consider calling a professional who knows what they are doing and have it inspected. I'm all for DYI and have on many occasions done just about every trade you can think of. But gas, no way. Call a pro.
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    CHECK LOCAL BUILDING CODES!!!!!!!
    They will tell you all you need to know. (pipe material, testing, depth of pipe and inspection's)
    16,500 gal Roman end with PebbleFina finish
    4 x 160 intelliflo pump
    Easytouch controls with an IC40 chlorinator
    Sta-rite cartridge filter
    A & A infloor cleaning system
    Pentair 5g LED pool light
    4JawChuck's Avatar
    Jun 2010
    Winnipeg, Manitoba, Canada
    223
    I have no idea about your local codes but you shouldn't be doing this yourself anyway, too many liabilities involved.
    However one product I am familiar with fits your requirements exactly, Gastite meets all the codes I am familiar with and it is jacketed flexible corrugated stainless steel...it doesn't require bonding and is easy to install although I think you still need 18" of cover not 12" to pass without exceptions made by the inspector.
    http://www.gastite.com/
    Here is a reference PDF regarding concealed fittings approval for the pipe with National Gas Code and approval letters for the US and Canada. I doubt you need concealed fittings in you setup but the document contains a lot of reference material.
    http://www.gastite.com/include/langu...edFittings.pdf
    One thing I will say is I would install a striker plate over the pipe underground even though its not required to meet code, for what it costs to lay a metal cover over the pipe (once its partially buried) and the possible ramifications of someone digging into it with a shovel inadvertantly later...its cheap insurance.
    55 Kilolitre in-ground 18'X36' vinyl lined kidney shape, 1HP pump, Jacuzzi 250lb sand filter, RayPak Delta T 200K BTU natural gas heater. New PoolWerks "Blue Diffusion" liner on May 26th-2011
    Avatar is my pool!
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    I would check the codes. Gastite + PVC jacketing (for venting leaks) would pass in my area, but as EVERYONE says so far, it depends on your local inspector. Usually if you are going to run under any type of slab, PVC jacketing would be required to contain and vent underground leaks to make sure they do not find their way into the home. Its also a good idea in general as someone with a shovel might get a nasty suprise one day. With PVC at least they would stop and wonder "what the heck is this?" and hopefully investigate. Underground also usually requires a tracer wire be buried with the pipe for locating, and a marking tape be located a few inches in the soil above the pipe to alert diggers.
    My training on gastite DID include bonding the pipe, and they sell bonding supplies for gastite, so 4JawChuck you may want to check your references for safety. (their disclaimer "no bonding requirements outside those mandated by national and local codes" can easily be misinterpreted to mean no bonding required, but most codes require bonding.)
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    4JawChuck's Avatar
    Jun 2010
    223
    Just to clarify, what I meant to say is no additional bonding required as you would with a plastic pipe install.
    I wouldn't bury any gas pipe without protection, not sure I would use PVC either...even if it met code. Seen too many crushed PVC pipes from heavy traffic overhead to trust it.
    Avatar is my pool!
    Well, it isn't going in the slab of concrete. It will be buried 1' below the slab. I already have the trench dug, and tomorrow I plan on taking the ole' Hilti and buzzing through the basement wall.
    Is the yellow poly stuff any good underground?
    My plumbing supplier for work sells it in rolls.
    Dec 2009
    2,690
    You need a licensed plumber to do this. Your asking for trouble. Sorry to be blunt, but the questions your asking tell me you have no idea what your doing. Call a pro, please. Again, gas is not a DYI job, period.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Tony...1ft is likely not enough. Check your code, that will tell you what is acceptable vs. not, with regards to both material to be used and burial/grounding requirements. Whether you chose to get a permit or not is your choice, but please do not endanger yourself and those around you by trying to save a few $'s.
    Outside of that advice, I'm locking the thread as looking up your locally required building requirements should be your next step.
