Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Replastering? How much money are we talking here?
    Ballpark. We have white plaster right now, I'm thinking its the cheapo stuff because it seems to have deteriorated fairly quickly.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Replastering? How much money are we talking here?
    Replastering cost varies quite a bit by area, so you may be on your own finding out. It also depends on the condition of the existing plaster and the shell and the size of the pool, and if any tile work needs to be done. I'd say figure at least $5000, and it could easily go $10-12,000.
    Guest
    John's numbers are good. It does depend on the perimeter footage of the pool, depth, if there is a spa, and surface chosen. An average pool and spa in my area would run around 5K for white plaster only.
    Aug 2007
    near the swamp
    806
    around $3800 here for white
    TFP_wanna_be's Avatar
    Orlando, FL
    129
    I'm in the market for a resurface too... I painted 3yrs ago and a few (too many) fault areas have reappeared. Not that I fault the paint in these areas as it appears the 'pool' is failing.
    Note: Paint is only a 12 month band-aid. 24 months and had the classic blue feet. My whole pool and deck are due for a refresh.
    The paint project cost me $700 if i recall.... Being in FL - I hope to get a better deal than $5K for plaster. I'm just getting it back in the swing of things... I may have a leak... This is day 2 of shock...
    Not to mention I want to plumb for the Polaris...
    QUESTION: I have a CareTaker system... I want to remove the heads, fill with crete, and have the new surface cover the area. Any feedback on that?
    My Intro Page: tfp-wanna-be-checking-in-t27499.html
    20K Gal IG Pool - Resurfaced 11/14 w/ Super Blue Diamond Brite
    I test with TF-100 and SpeedStir
    1.5Pentair / 36sq DE filter
    Polaris 380 (love this thing)
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    any ideas what wholesale cost on 60 bags of SGM diamond brite is?
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Mar 2009
    Charlotte, NC
    539
    I may re-plaster in a few yrs & am considering pepple tech because it lasts longer so in the long run about the same money but less "re-make" hassels.
    I think they guarantee the peppletech for 20yr? Is that true & is my thinking sound re pepple tech being a better choice in the long run?
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Guest
    P-Tec is indeed very long lasting, but they do not have a 20 year warranty. I don't know anyone who does (Wet Edge has a pretty funny 15 year warranty, where they don't really warranty anything!), so check with the source instead of the salesman!
    I have P-Sheen, and it is going on 9 years old now. The smaller rock (as opposed to P-Tec), in my opinion, makes for a denser finish, and has less plaster exposure. That should be the longest lasting finish. The last I checked, God only made so many rocks and then He quit! I'm thinking the rocks ain't going anywhere (I run some remodel leads for the Gemstone owner here, and he is considering a one million year warranty on the Gemstone finish, but it applies to only the rocks!), so more is better. The smaller rock just lays down tighter, so I prefer it over the larger rock.
    Proper water chemistry still plays a huge part in life expectancy. If you allow the plaster that holds the rock in place to be compromised, you will have problems, just as you will with any other finish. If you go with P-Tec, take care of it and it will take good care of you!
    tdrum1's Avatar
    Aug 2010
    Indialantic, FL
    36
    It cost me $6,300.00 for a re-plaster w/Florida Gem. So far it has only been a week since the pool has been filled but things are starting to look good. The also replaced a bunch of cracked tile and repaired the leaks.
    My pool was about 25 years old and was leaking like a sieve.
    33K gal shotcrete w/new Florida Gem finish, Pentair Intelliflo VS, ProClean Waterway Filter, Rome TI 130 heatpump, Pentair Intellichlor 40k SWG and Intellibrite 5G spa and pool lights.
    Holy ****! I wonder how much one of the kids would fetch on the black market?
    I'm kidding. No, but seriously, anyone want one?
    Taz's Avatar
    Jul 2010
    NE FL
    80
    Guamgal - You are probably looking at a nice bit of change to get it done properly since you are in Guam. I'm sure someone has a cousin (& btw - it seems everyone is related - a friend at my wife's work remarked that it was almost impossible to date there) who can do it on the side but you should make sure you do everything in writing. BTW: I was stationed there 89-92.
    Recommend you keep the kid - you'll need the tax deduction.
    30' x 15' kidney shaped, 3.5-5.5 ft deep, wet-mix shotcrete inground, AutoPilot Digital SWG - RC35/22 cell, 36" main drain, 1 skimmer, 4 returns, Dyna-Pro 1 HP, Sta-Rite 2 (PLM100) filter, Polaris 360 cleaner, Marbletite (Marquis/Bluestone), Screen enclosure
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Quote Originally Posted by TFP_wanna_be
    I think that would work just fine. Do you have wall returns to circulate the water after the caretaker is gone?
    tdrum1's Avatar
    Aug 2010
    Indialantic, FL
    36
    Hey, I was there in '78 - 80!
    I think the only pools back then were on the bases and the few hotels they had...
    You are probably right about the cousin, LOL! I'll ask around, I'm sure I know someone who knows someone.
    I wonder how much the island has changed since 1980?
    Orlando, FL
    129
    [quote=Melt In The Sun]
    Quote Originally Posted by "TFP_wanna_be":1cit15a4
    I think that would work just fine. Do you have wall returns to circulate the water after the caretaker is gone?[/quote:1cit15a4]
    yes thank you! I have two returns. 1 in the shallow and the other is in the deep end pointing to the skimmer. Thanks again!!!
    Hope to get some quotes soon - I'm ready to make it happen!!!
    susa's Avatar
    Oct 2010
    Deep South
    578
    15 X 30 pool in S.Florida, 15,000 gallons
    Diamond Brite
    One day to chip out any hollow spots and expose gunite
    One day to plaster, two coats, Acid Washed before fillup
    1700.00
    Orlando, FL
    129
    WOW - I paid $6700 in Central FL for prep w/ bondkote, Diamond Brite, tile removal and new tile. Patched a few holes and exposed rebar. Also retooled the leak on the skimmer box... I didnt price shop - in general I got 2 quotes... I went with the contractor that was most responsive. I tried to get more quotes, but people would not call me back... If I had it to do again, I would press harder may see how far my dollar can stretch knowing is wham-bam-see-you-later-3-day project...
    16x32 8.5" diving pool - took almost 60bags of DB...
    Guest
    You gotta remember that you may not be comparing apples to apples here. susa may (not saying he did!) have got a "pool guy who has a buddy who knows how to plaster" that did the work. May have been a "cash job", and by guys with no insurance or workers comp. I see these guys picking up "plasterers" and "trowelers" all the time at Home Depot. I would not consider those guys legitimate, not would I expect the best work (or a warranty, let alone a return call if you called with a problem).
    Your price sounds good. As for the time frame, there is no reason to prolong the work. Properly done work, by a well trained crew, goes pretty quickly. They get paid for the knowledge and experience, and not for how long it takes
    Sounds like you used a reputable contractor. I hope you both are happy with the end product and get many, many years of life out of your pools
    Dec 2009
    Central Massachusetts
    2,690
    WOW - I paid $6700 in Central FL for prep w/ bondkote, Diamond Brite, tile removal and new tile. .
    I bolded the location. Work like this done in Florida has no relationship to the real world,
    Everything that has to do with pool construction, landscaping, etc is cheaper in Florida, by far.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
  20. Back To Top    #20
    ronipooh's Avatar
    Dec 2013
    Kissimmee, Florida
    64
    So WHY is everything Pool cheaper in Florida? Since that's where I live, I just want your reasoning.
    13,700 gal, outdoor IG Plaster, (deteriorating)Sta rite Posi Flo II ptm 70 Cartridge, Paramount PCC 2000 in floor pop up sweeper, RedLeopard Orbit automatic pool cleaner, FLOLight return eyeballs, 1 HP Pentair Superflo single speed pump, built in 1992
    370 Gal 2005 stand alone Marquis Destiny spa w/Ozonator, chlorinated
