Thread: Need help: Ph and TA high before closing
    I am preparing pool for closing and I shocked the pool but my TA and PH are high and can't get to low. Need help with it.
    FC 18 (It was 23 after shock and reduced by 5ppm in 24hrs, I used BBB method.)
    CC 0
    TA 115
    PH 8.2
    CH 110
    I added Dry Acid 3lbs by mixing it in water to the pool. Ph came down to 7.8 after 1hour, but went back to 8.2 by end of the day.
    What should I do?
    1. Should I be reducing the Ph to 7.2 - 7.4 and TA to 80 -90 before closing?
    2. Or does it matter if Ph his high before closing?
    3. Will it affect my new Vinyl?
    Please advise.
    33,000 gallon (20x40), Sand, IG, Vinyl
    South Central NJ
    3,192
    Re: Need help: Ph and TA high before closing
    Try a different test kit. Bring the pH down.
    Scott
    Owner of - PoolGuyNJ LLC
    22,544
    AT that hhigh an FC your pH test will read artificially high. You need to bring the FC down to about 10 and test it again. If it's still high you should bring the pH down to 7.2 - 7.4 then raise the FC back up.
