Thread: blowing returns
    May 2009
    Trenton NJ
    497
    blowing returns
    I was thinking of keeping the water just below the skimmer. This past summer I had a leak in the main drain and plugged it off so I can't drain the water any lower than the skimmer. I do not have a pump. Would this be ok, or do I need to go out and buy a pump?
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Mar 2009
    Charlotte, NC
    539
    Re: blowing returns
    If your summer pump is Off & you want to keep the water below the skimmer, you'll need a pump as you said to acheive that.
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    May 2009
    Trenton NJ
    497
    Re: blowing returns
    My pool pump is ON but I can not pull water below the skimmer. Is there any way of using my pool pump instead of buying a separate pump?
    22,544
    Re: blowing returns
    Do you have a manual vacuum that hooks into the skimmer throat? Hook it up and stick teh hose in the pool and pump to waste. Or just use the vacuum hose to siphon off water.
